Noahkk19 Posted November 2, 2004 Report Share Posted November 2, 2004 What are the different triggers that will cause the ECU to run boost in this safety mode? 94 850 Turbo Link to comment Share on other sites More sharing options...
slick50 Posted November 3, 2004 Report Share Posted November 3, 2004 I have never seen a volvo run a safety setting for boost. I know it will pull timing back if the motor knocks. If it see's any pre detonation pulling the timing back will down the boost on the turbo. If that answers your question.as far as what could cause pre detonation, well a lot of things. To much boost not enough fuel, sensors themselves throwing wrong signals to cause fuel mixture to be off, ie MAF, Oxygen sensors,ECT, etc. But never seen boost to be lowered for a safety with vehicle ECM. Link to comment Share on other sites More sharing options...
Noahkk19 Posted November 3, 2004 Author Report Share Posted November 3, 2004 Oh I thought there was some trigger that caused the ECU to run a max boost of 3psi. I DONT KNOW where I got that from though. But your explanation makes sense. I would hope I don't get horrible pre-detonation on a all stock motor running 93 octane. I think it's just time for a good all around tune up, and I know I have a noticeable crack in a pretty big turbo hose. So looks like it's time to just start cracking away at things one by one. Link to comment Share on other sites More sharing options...
Noahkk19 Posted November 4, 2004 Author Report Share Posted November 4, 2004 You guys think a completely burnt out cat could cause a massive pull back of timing? Link to comment Share on other sites More sharing options...
MrWinkey Posted November 4, 2004 Report Share Posted November 4, 2004 Nope ....But a clogged cat will... Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 4, 2004 Report Share Posted November 4, 2004 when/if I threw a cat code it'd only let me boost like 5 psi (weird, but true) Link to comment Share on other sites More sharing options...
jross Posted November 4, 2004 Report Share Posted November 4, 2004 When my front O2 went, it went into a 3-psi limp mode. OBD-II code was P0133, slow front response Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 4, 2004 Report Share Posted November 4, 2004 just throw a MBC on it, you still have the fuel there, and crank up the boost Link to comment Share on other sites More sharing options...
Noahkk19 Posted November 5, 2004 Author Report Share Posted November 5, 2004 ahhh, I love you, always comming up with the best solutions for those of us who are too cheap to fix everything the right way Link to comment Share on other sites More sharing options...
JHEIII874T5M Posted November 5, 2004 Report Share Posted November 5, 2004 :D college spending at its best Link to comment Share on other sites More sharing options...
