jda2000 Posted November 2, 2004 Report Share Posted November 2, 2004 Just did my first oil change over the weekend after installing a fumoto oil drain valve 4K miles ago. Great idea, the japanese automakers use these valves in the new cars in Japan, but not in the states.Man, this is the way to change the engine oil. No mess, no danger of stripped threads, no need for aluminum washer, no need to torque. For those inquiring minds, you'll need the adapter also. I got the one with a nipple and oil is drained directly to a container.PS: I don't work for this company , nor do I own stock in the company. Just passing along a great idea.fumoto engine oil drain valve Link to comment Share on other sites More sharing options...
theunderlord Posted November 2, 2004 Report Share Posted November 2, 2004 I had this on the truck... worked well.. The Fram quick drain thingy seems pretty cool too.. never used it tho... Link to comment Share on other sites More sharing options...
gatlin Posted November 2, 2004 Report Share Posted November 2, 2004 Agreed. I've got them on my Volvos and my Explorer. It was money well-spent. Link to comment Share on other sites More sharing options...
Mesoam Posted November 2, 2004 Report Share Posted November 2, 2004 that thing is pretty spiffy...but i don't like these 2 points.....Drive carefully at all times, and if you run over any foreign object on the road, pull over and check the valve for any damage or leak. N-Series valve(with Nipple to accept hose) is not recommended for passenger cars with low ground clearance. Link to comment Share on other sites More sharing options...
jda2000 Posted November 3, 2004 Author Report Share Posted November 3, 2004 that thing is pretty spiffy...but i don't like these 2 points.....←In the 850/70 series the low clearance is not a problem, since the drain hole is facing backwards and the valve and nipple also face backwards. Link to comment Share on other sites More sharing options...
theunderlord Posted November 3, 2004 Report Share Posted November 3, 2004 In the 850/70 series the low clearance is not a problem, since the drain hole is facing backwards and the valve and nipple also face backwards.←very good point.has anyone used the Fram drain? Link to comment Share on other sites More sharing options...
prasamin Posted November 3, 2004 Report Share Posted November 3, 2004 sweet, for the 5 cyl engines, they have the drain with nipple, and adapter for 32 plus 3 shipping...35 for the setup is not bad...ordering me one of them thar drains. Link to comment Share on other sites More sharing options...
jda2000 Posted November 3, 2004 Author Report Share Posted November 3, 2004 lubespecialiststhese folks carry the valve with nipple for $21.95, but you have to call them to add the adapter since is not listed online. Link to comment Share on other sites More sharing options...
