vlvman Posted April 12, 2009 Report Share Posted April 12, 2009 I have a 82 244 with B21F, NA, K-Jet, Chrysler ignition. My emissions label is smudged and I have searched for timing spec, and have found numbers between 8-14 BTDC. So what is the correct spec? If you have K-Jet and have checked your fuel pressures (line and control) please post them. My line pressure is 75-76, I just installed a used fuel system and have not checked the control pressure on this system yet. Link to comment Share on other sites More sharing options...
Three Fat Tigers Posted April 12, 2009 Report Share Posted April 12, 2009 12º BTDC at 900 rpm, vacuum line to the ICU disconnected. Your line pressure is normal.Check out kjet.org, they have some green books that will help you with the control pressure:http://www.k-jet.org/documents/greenbooks/200-series/ Link to comment Share on other sites More sharing options...
