washdup Posted April 17, 2009 Report Share Posted April 17, 2009 Just bought a used USA Spec for use with my SC-816. Only thing is, there's no instructions. I've done a bit of searching and seen that folks have had issues with grounding; but I don't see what appears to be a ground wire. Any and all help will be appreciated. Link to comment Share on other sites More sharing options...
Young Burnsy Posted April 17, 2009 Report Share Posted April 17, 2009 Post pics. Link to comment Share on other sites More sharing options...
flyfishing3 Posted April 17, 2009 Report Share Posted April 17, 2009 if there is a yellow wire thats the ground for the usa. IIRC. Link to comment Share on other sites More sharing options...
mkc70 Posted April 17, 2009 Report Share Posted April 17, 2009 Just bought a used USA Spec for use with my SC-816. Only thing is, there's no instructions. I think there's a couple of extra cables that could be used as inputs that I won't be using, and there's a red and yellow wire that looks like Lucky had formed a little loop at the end. I've also done a bit of searching and seen that folks have had issues with grounding; but I don't see what appears to be a ground wire. Any and all help will be appreciated.Viewable install directions for all models are available at usaspec.com. Link to comment Share on other sites More sharing options...
washdup Posted April 17, 2009 Author Report Share Posted April 17, 2009 Thanks, I checked the mfr install instructions, but they do not cover the Volvo adaptor. Anyway, here's what I've got: Link to comment Share on other sites More sharing options...
flyfishing3 Posted April 17, 2009 Report Share Posted April 17, 2009 the one i had for my HU 803, the yellow was the ground. i had to move it around some to find the best ground. most of the metal i found under the dash is small and not connected to much. hunt around.other than that, looks pretty straight foward. i put the rca box in the glove box so i had access to the rca's if i wanted to add more stuff. Link to comment Share on other sites More sharing options...
mkc70 Posted April 17, 2009 Report Share Posted April 17, 2009 Thanks, I checked the mfr install instructions, but they do not cover the Volvo adaptor. Anyway, here's what I've got:and here is the little loop:The red(Yellow/Violet) and yellow wire(Green/Brown) are for ignition and constant power respectfully. http://usaspec.com/userfiles/editor/file/581PA11HON.pdf Additionally you will need to purchase the CBP VOL cable to make yours work on an older Volvo. Good luck. Link to comment Share on other sites More sharing options...
Ipd Posted April 17, 2009 Report Share Posted April 17, 2009 Everything you have is all you'll need to make it work on a SC8XX radio.The blue connector is not used and the smaller DIN cable connects to the CD port in the back of the radio.As mentioned the red and yellow wires are for 12v key on and constant power.That's all there is to it. Link to comment Share on other sites More sharing options...
washdup Posted April 17, 2009 Author Report Share Posted April 17, 2009 Everything you have is all you'll need to make it work on a SC8XX radio.The blue connector is not used and the smaller DIN cable connects to the CD port in the back of the radio.As mentioned the red and yellow wires are for 12v key on and constant power.That's all there is to it.Thanks Lucky. Where do the yellow and red connect to? No separate ground or did I miss something? Link to comment Share on other sites More sharing options...
washdup Posted April 17, 2009 Author Report Share Posted April 17, 2009 other than that, looks pretty straight foward. i put the rca box in the glove box so i had access to the rca's if i wanted to add more stuff.Sounds like the yellow is diff on this model. I think my preference is to route the iPod cable to the center console, but may go to the glove box if that looks too complicated. You're talking about the box itself though. Link to comment Share on other sites More sharing options...
Ipd Posted April 17, 2009 Report Share Posted April 17, 2009 Thanks Lucky. Where do the yellow and red connect to? No separate ground or did I miss something?I just run the red and yellow wires to pins 12 and 13 on the radio connector. can't remember which is which on the radio connector but you can use a test light or multimeter to determine for sure.yellow wire needs 12v constant and red wire needs 12v switched (key on). Link to comment Share on other sites More sharing options...
washdup Posted April 17, 2009 Author Report Share Posted April 17, 2009 I just run the red and yellow wires to pins 12 and 13 on the radio connector. can't remember which is which on the radio connector but you can use a test light or multimeter to determine for sure.yellow wire needs 12v constant and red wire needs 12v switched (key on). Just searched and found: 12 is red (constant) and 13 is yellow (accessory). I think I'm ready. Will report back. Thanks for the help everyone. Now back to work. ;) Link to comment Share on other sites More sharing options...
Ipd Posted April 17, 2009 Report Share Posted April 17, 2009 Red wire on the adapter is accessory (12v key on) and yellow wire on the adapter is 12v constant (battery power).Pin 12 on the radio harness is constant power and pin 13 is key on power. Link to comment Share on other sites More sharing options...
Young Burnsy Posted April 18, 2009 Report Share Posted April 18, 2009 Do you guys have any interference noise on your units?I do and I'm wondering if I should just change my ground or if I should get a noise eliminator. Link to comment Share on other sites More sharing options...
beadgc23 Posted April 18, 2009 Report Share Posted April 18, 2009 The red and yellow wires work the other way around too, but then your iPod won't charge with the ignition off. Ask me how I know... Link to comment Share on other sites More sharing options...
