jdlc Posted April 20, 2009 Report Share Posted April 20, 2009 On it's way to my doorstep.Any trick/pit falls on install? Estimate time to do this?(Console removal I've done in the past, no issue there.)Thnx. Link to comment Share on other sites More sharing options...
fattmatt805 Posted April 20, 2009 Report Share Posted April 20, 2009 from what ive heard they can be a little tricky to install the shifter into the cage, but if that pic is what you have, should be very straightforward and just 4 bolts, since its already instaled inn the cage Link to comment Share on other sites More sharing options...
jdlc Posted April 20, 2009 Author Report Share Posted April 20, 2009 from what ive heard they can be a little tricky to install the shifter into the cage, but if that pic is what you have, should be very straightforward and just 4 bolts, since its already instaled inn the cageSweet, good to know. Yes, that's what it'll be. Link to comment Share on other sites More sharing options...
jdlc Posted April 25, 2009 Author Report Share Posted April 25, 2009 Sweet, good to know. Yes, that's what it'll be.6 bolts.And removing and installing the cables can be a PITA for 1st timers (like me).The shift is much crispier now, and I made it a bit tight by re-seating the big ball without any play.Will test-drive later... Link to comment Share on other sites More sharing options...
jdlc Posted April 25, 2009 Author Report Share Posted April 25, 2009 6 bolts.And removing and installing the cables can be a PITA for 1st timers (like me).The shift is much crispier now, and I made it a bit tight by re-seating the big ball without any play.Will test-drive later...Woot.Worth the $$$ - don't even care the boot is all fubar - will replace it with some micro-fibre or something.Shift is crisp and precise and, well, travel is short.Hanx to Melvin, even though he totally snubbed me when I asked if he has any tips in install .I guess he figured I'll figure it out . Link to comment Share on other sites More sharing options...
T5Manual850 Posted April 28, 2009 Report Share Posted April 28, 2009 where can one of these be purchased?? Link to comment Share on other sites More sharing options...
jdlc Posted April 30, 2009 Author Report Share Posted April 30, 2009 where can one of these be purchased??est still carry them. Link to comment Share on other sites More sharing options...
