Tom93R1 Posted April 21, 2009 Report Share Posted April 21, 2009 What a great day! I have been trying to get through emissions, had one last check engine code to take care of. The car threw a P0336 for cam angle sensor. It is a very intermittent problem only when light cruising and starting to go up a hill as the load increases then the car studders. I thought it was the tranny hunting at first but just figured out its this cam angle sensor.Any way, I swapped in a cam angle sensor I found at the yard and the car wouldnt start. I thought must be a bad sensor so put my original back in. Car still won't start! I found I get no spark. Also no check engine codes are thrown. I love my car.Any ideas? I can't imagine that I could have killed my coil while doing this, I would guess it has to be related to the sensor somehow. Maybe the code I had originally was from the wiring harness, bad wire in there... any other things to look at? Link to comment Share on other sites More sharing options...
Tom93R1 Posted April 21, 2009 Author Report Share Posted April 21, 2009 Is there a way to verify the functionality of a cam angle sensor? If it wasn't a $200 part I would just go buy a new one to try... Or should I take another trip to the yard and try a second one? Link to comment Share on other sites More sharing options...
Scootdiggity Posted April 21, 2009 Report Share Posted April 21, 2009 Is there a way to verify the functionality of a cam angle sensor? If it wasn't a $200 part I would just go buy a new one to try... Or should I take another trip to the yard and try a second one?I never heard of wiring issue, but possible. Also was the car you got it off of sitting a long time as well and what were the miles on junk car. I have a cam sensor off a 45k s70 which is compatiable if interested check for sale thread for my part out ad. Link to comment Share on other sites More sharing options...
Boglin Posted April 21, 2009 Report Share Posted April 21, 2009 What a great day! I have been trying to get through emissions, had one last check engine code to take care of. The car threw a P0336 for cam angle sensor. It is a very intermittent problem only when light cruising and starting to go up a hill as the load increases then the car studders. I thought it was the tranny hunting at first but just figured out its this cam angle sensor.Any way, I swapped in a cam angle sensor I found at the yard and the car wouldnt start. I thought must be a bad sensor so put my original back in. Car still won't start! I found I get no spark. Also no check engine codes are thrown. I love my car.Any ideas? I can't imagine that I could have killed my coil while doing this, I would guess it has to be related to the sensor somehow. Maybe the code I had originally was from the wiring harness, bad wire in there... any other things to look at?Coud be a combonation of issues CMP sensor as well as coil module. See if you can get your hands on a used coul assembly or there are steps for checkin mhz on that module. Link to comment Share on other sites More sharing options...
Tom93R1 Posted April 21, 2009 Author Report Share Posted April 21, 2009 On my way in to work I grabbed the only other cam angle sensor from the wrecking yard, will give it a shot tonight. If that doesn't do it then another trip tomorrow morning and I will grab the coil. Wish I grabbed that this morning, oh well. thanks! Link to comment Share on other sites More sharing options...
Tom93R1 Posted April 22, 2009 Author Report Share Posted April 22, 2009 I installed the other new to me cam angle sensor and the car fired right up! I am guessing now that the very good condition body 850 I got the first one from was in there due to an engine that wouldn't start... and wouldn't start because of a bad cam angle sensor. Apparently my old one completely failed after I removed it, and wouldnt work to start the car again. thanks for the help guys! Link to comment Share on other sites More sharing options...
