bmx9854 Posted April 27, 2009 Report Share Posted April 27, 2009 Is the USA SPEC adapter compatible with the iphone? If, so can I play music other than itunes through it such as the pandora app? Also can I use the adapter with a factory amp (850 R)? And lastly, can I add an aftermarket mono amp for a sub in conjunction with the ipod adapter and factory amp? Thanks in advance. Link to comment Share on other sites More sharing options...
Young Burnsy Posted April 27, 2009 Report Share Posted April 27, 2009 Mine is supposed to be. Link to comment Share on other sites More sharing options...
mkc70 Posted April 27, 2009 Report Share Posted April 27, 2009 Is the USA SPEC adapter compatible with the iphone? If, so can I play music other than itunes through it such as the pandora app? Also can I use the adapter with a factory amp (850 R)? And lastly, can I add an aftermarket mono amp for a sub in conjunction with the ipod adapter and factory amp? Thanks in advance.Yes to all. Iphone 2g requires a different charging cable, but all you do is specify in your order. Link to comment Share on other sites More sharing options...
beadgc23 Posted April 27, 2009 Report Share Posted April 27, 2009 Is the USA SPEC adapter compatible with the iphone? If, so can I play music other than itunes through it such as the pandora app? Also can I use the adapter with a factory amp (850 R)? And lastly, can I add an aftermarket mono amp for a sub in conjunction with the ipod adapter and factory amp? Thanks in advance.1 Yup - both 1G and 3G. The older cable will charge the 1G but not the 3G, the new cable will charge both. Scosche (sp?) sell an adapter, but the cable is only $15 or so direct from USA•SPEC.2 Yups again. I like LastFM because I think it sounds better, and RSSplayer (I think) because it allows you to download podcasts over 3G. Watch out - switching the HU on or off will flip the iPhone back to the Music app.3 Once again yep - the unit powers off the B+ & ACC cables, plugs into the CD-Changer socket. Therefore you loose the CD changer...4 Slightly less positive because I've never done it, but you could splice in RCA sockets to the front or rear L & R lines on the factory cable and run an RCA cable to your new amp. I've seen several writeups about. BTW, the 850 R amp is 4x40 @ 10% THD IIRC - how about a decent 5 channel amp? I also got a huge improvement in SQ by going to the SC-901Extra coolness - when a call comes in, music quickly fades and the call is routed to your bluetooth headset or handsfree. Hang up and the music fades back in again.Can't remember when I was last so positive :D Link to comment Share on other sites More sharing options...
