Brad850 Posted April 27, 2009 Report Share Posted April 27, 2009 If i buy the CBV upgrade kit from Viva performance ( http://www.vivaperformance.com/catalog/pro...products_id=779 ) will i have to buy shims for it too? Or will the new spring be sufficient enough for my boost levels (Ipd Ecu 14.5 psi). Quickbrick motor sport's CBV kit sells the diaphragm and shims but no spring so I'm not sure which one to buy.Or should i just buy this? http://www.forgemotorsport.co.uk/content.a...product=FMFK050There was recently a thread on this but it didn't really answer any of my questions as to which is the best route to go. If the forge motor sports one is by far the best I wouldn't mind spending the money, but if there is really no difference It'd be nice to save a few bucks. Link to comment Share on other sites More sharing options...
Dave 54 Posted April 27, 2009 Report Share Posted April 27, 2009 Go with the forge, that's what I got. QBM is no longer around, and I don't have any input on the Viva rebuild kit other than it appears to be all stock replacement parts. Not sure though. Link to comment Share on other sites More sharing options...
dublin14 Posted April 27, 2009 Report Share Posted April 27, 2009 If i buy the CBV upgrade kit from Viva performance ( http://www.vivaperformance.com/catalog/pro...products_id=779 ) will i have to buy shims for it too? Or will the new spring be sufficient enough for my boost levels (Ipd Ecu 14.5 psi). Quickbrick motor sport's CBV kit sells the diaphragm and shims but no spring so I'm not sure which one to buy.Or should i just buy this? http://www.forgemotorsport.co.uk/content.a...product=FMFK050There was recently a thread on this but it didn't really answer any of my questions as to which is the best route to go. If the forge motor sports one is by far the best I wouldn't mind spending the money, but if there is really no difference It'd be nice to save a few bucks.Frank at Eurosport sells the Forge kit for $195! I would NOT order from Viva... George does not deserve any more buisness! Link to comment Share on other sites More sharing options...
lookforjoe Posted April 27, 2009 Report Share Posted April 27, 2009 I have a QBM diaphragm if you're interested. I used two fender washers & the stock spring; it held over 20psi no problem.$45 shipped if you want it. Link to comment Share on other sites More sharing options...
7 VII 7 Posted April 27, 2009 Report Share Posted April 27, 2009 doesnt FORGE make a CBV? Link to comment Share on other sites More sharing options...
Dave 54 Posted April 27, 2009 Report Share Posted April 27, 2009 doesnt FORGE make a CBV?They make a purdy blanking plate, no CBV though that I could find. Link to comment Share on other sites More sharing options...
7 VII 7 Posted April 27, 2009 Report Share Posted April 27, 2009 They make a purdy blanking plate, no CBV though that I could find.well couldn't it be the same for an mitsi turbo? Link to comment Share on other sites More sharing options...
troyhyde Posted April 28, 2009 Report Share Posted April 28, 2009 The other day I saw a correct Mitsubishi replacement (the red one) on eBay. I think it was around $30. I figured I'd buy several since shipping is from Japan and is a little high for a single piece.I did the JB Weld / washer thing but honestly it is probably perfectly fine stock with the new spring. Now the wastegate actuator on the other hand.... if you've got a 15G it is without a doubt marginal at higher boost levels. The 16T actuator is better.I'd do a stock style replacement on the CBV and find a good actuator if I were going to dig around down there... Link to comment Share on other sites More sharing options...
mkc70 Posted April 28, 2009 Report Share Posted April 28, 2009 The other day I saw a correct Mitsubishi replacement (the red one) on eBay. I think it was around $30. I figured I'd buy several since shipping is from Japan and is a little high for a single piece.I did the JB Weld / washer thing but honestly it is probably perfectly fine stock with the new spring. Now the wastegate actuator on the other hand.... if you've got a 15G it is without a doubt marginal at higher boost levels. The 16T actuator is better.I'd do a stock style replacement on the CBV and find a good actuator if I were going to dig around down there...Ordered that CBV off Ebay last summer. Was defective right out of the package and seller would not respond. So if you get a defective one good luck on getting a response. I would get a good one off a fellow forum member till IPD comes out with their heavy duty version along with replacement high rate springs. Hopefully sooner than later, but I am patient. Link to comment Share on other sites More sharing options...
UnknownSoldier Posted April 28, 2009 Report Share Posted April 28, 2009 The orange CBV that VIVA sells and can be found on ebay is the proper mitsubishi one. I have been running one for a while now and no problems at all. Kando_Dynamic is a good seller, not sure if he has any left, i'm waiting for him to order me a wastegate actuator for the 16T, 4 weeks to go. Also, when i bought the diaphragm it arrived like a few days later on a weekend also, very quick delivery. Link to comment Share on other sites More sharing options...
Brad850 Posted April 28, 2009 Author Report Share Posted April 28, 2009 Alright thank you everyone for all the replies/info i just bought the viva kit off mk3less. Link to comment Share on other sites More sharing options...
Snabb T5M Posted April 28, 2009 Report Share Posted April 28, 2009 Did the Viva kit come with the necessary shims? As I am also looking at this upgrade.Alright thank you everyone for all the replies/info i just bought the viva kit off mk3less. Link to comment Share on other sites More sharing options...
7 VII 7 Posted April 28, 2009 Report Share Posted April 28, 2009 the ViVa kit comes with a brand new Mitsi diaphram, the spring is made to be stronger than stock so therefore you do not need shims unlless you are running crazy boost Link to comment Share on other sites More sharing options...
Snabb T5M Posted April 28, 2009 Report Share Posted April 28, 2009 oh ok, gotcha. Since I'm only running an IPD ECU tune with I think only 16lbs of boost it should be ok with no shims then.the ViVa kit comes with a brand new Mitsi diaphram, the spring is made to be stronger than stock so therefore you do not need shims unlless you are running crazy boost Link to comment Share on other sites More sharing options...
Snabb T5M Posted April 28, 2009 Report Share Posted April 28, 2009 See, this is why I am naive when it comes to car things. The CBV instructions state the amount of shims to use depending on the amount of boost, and give boost levels from 9 - 20 psi. For 10 psi of boost, it states to use 2 shims, for 16 psi of boost, 4 shims. If the shims aren't needed unless running crazy boost levels, why state the amount of shims then? So based on the instructions, I was thinking I needed 4 shims in the CBV. In summary, I shouldn't need any shims in the Viva CBV based on the stiffer spring. the ViVa kit comes with a brand new Mitsi diaphram, the spring is made to be stronger than stock so therefore you do not need shims unlless you are running crazy boost Link to comment Share on other sites More sharing options...
