pjcrump Posted April 28, 2009 Report Share Posted April 28, 2009 I have a 2000 S80 and today none of the Climate Control system works (no lights or function)and none of the Center Console switches are functional (no lights or function). And to top it off,none of the lights that indicate which gear you are in (on the floor) work.Everything else on the car works and lights up fine (Dash Lights & Function, Radio,Cruise, Directionals, Drivers seat adjustment, Windows, Seats, Wipers, Lights)I have checked all of the fuses in the passenger compartment for the Blower Motor and anything else that seems relevant but nothing stands out.Seems to me that it's a fuse but I cannot locate a bad one..Thanks in advance.. - PJ Link to comment Share on other sites More sharing options...
MrWinkey Posted April 28, 2009 Report Share Posted April 28, 2009 Sounds as if the console or something was removed and something was not plugged back in?>> Hard to say but that is my first guess ;) Link to comment Share on other sites More sharing options...
shanks31 Posted April 28, 2009 Report Share Posted April 28, 2009 Your climate control module has gone kaput... it happened in my 02 s60 as well and my buddies 99 s80. get the part off of ebay ( s80 is usually about $40 shipped). dont even talk to the stealership, they will want at least 700 for the part and another couple hundred for programming. and if for some reason it isnt plug and play you might be able to find a local shop that can do a cheap programing job for you. good luck Link to comment Share on other sites More sharing options...
Guest Guest_PJCrump_* Posted April 29, 2009 Report Share Posted April 29, 2009 Your climate control module has gone kaput... it happened in my 02 s60 as well and my buddies 99 s80. get the part off of ebay ( s80 is usually about $40 shipped). dont even talk to the stealership, they will want at least 700 for the part and another couple hundred for programming. and if for some reason it isnt plug and play you might be able to find a local shop that can do a cheap programing job for you. good luckWhere is this module located at?? Is there a way to test it? Link to comment Share on other sites More sharing options...
shanks31 Posted April 29, 2009 Report Share Posted April 29, 2009 Where is this module located at?? Is there a way to test it?the module is the actual climate control housing itselfthat is if your had auto climate control otherwise it just has a temp knob where the little guy is Link to comment Share on other sites More sharing options...
shanks31 Posted April 29, 2009 Report Share Posted April 29, 2009 sorry: and there really isnt a way to test it as far as i know. its a fairly common failure but one on ebay from LKQ auto parts should do the. i ordered mine from them a week ago and im replacing it the second it arrives. warm days are no good without A/C Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted April 30, 2009 Report Share Posted April 30, 2009 I replied to your other thread. Link to comment Share on other sites More sharing options...
MrWinkey Posted April 30, 2009 Report Share Posted April 30, 2009 I replied to your other thread.I totally miss posted on this as I haven't been myself lately however this gentleman(IHSB) is more than quailified to assist you! Trust me I have seen his posts. Shanks is probably spot on though. ;) Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 1, 2009 Report Share Posted May 1, 2009 Sounds as if the console or something was removed and something was not plugged back in?>> Hard to say but that is my first guess This is very possible as well. I have seen it more than once after ipod, sirius etc. have been installed. Link to comment Share on other sites More sharing options...
