Charles G Posted May 1, 2009 Report Share Posted May 1, 2009 I'm in the process of removing my radiator to bring it to a local radiator shop to have it tested. I removed the engine fan and radiator hoses. But I can't seem to detach the oil cooler hoses from the transmission/transaxle. The plastic around the connection was brittle and broke off easily. How can I detach the oil cooler hoses from the radiator? Link to comment Share on other sites More sharing options...
vegasjetskier Posted May 1, 2009 Report Share Posted May 1, 2009 I don't know if this will help or not, but here are the VADIS directions:S80RadiatorReplacement.pdf Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 1, 2009 Report Share Posted May 1, 2009 Those green clips can be a PITA. If you can fit a small screwdriver in there to release the clip you will probably be able to get it out. It may require some tugging and cursing. That seems like an awful lot of work to test a radiator. If I went through the trouble to pull it out just to check it and it was original I think it would be wise to just put a new one in. You would probably save yourself a lot of work. Link to comment Share on other sites More sharing options...
MrWinkey Posted May 2, 2009 Report Share Posted May 2, 2009 As suggested you can remove the clips with a small screwdriver by pressing in on the tabs. I'm questioning why your having it tested though? What is the issue?You will need new green clips for re install ;) Link to comment Share on other sites More sharing options...
Charles G Posted May 7, 2009 Author Report Share Posted May 7, 2009 Those green clips can be a PITA. If you can fit a small screwdriver in there to release the clip you will probably be able to get it out. It may require some tugging and cursing. That seems like an awful lot of work to test a radiator. If I went through the trouble to pull it out just to check it and it was original I think it would be wise to just put a new one in. You would probably save yourself a lot of work.Thanks a bunch. I will try that. Link to comment Share on other sites More sharing options...
Charles G Posted May 7, 2009 Author Report Share Posted May 7, 2009 As suggested you can remove the clips with a small screwdriver by pressing in on the tabs. I'm questioning why your having it tested though? What is the issue?You will need new green clips for re install Okay, I guess testing the radiator was a dumb idea. I'll just replace it and save the $50 testing fee. Besides, I just read a Volvo TSB that stated that one of the main reasons for transmission failure is contamination of transmission fluid with antifreeze. As it turns out, my transmission has been overhauled 3 times in the past 2 years and is failing yet again. Time for a new radiator. Thanks a bunch for your advice. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 7, 2009 Report Share Posted May 7, 2009 Okay, I guess testing the radiator was a dumb idea. I'll just replace it and save the $50 testing fee. Besides, I just read a Volvo TSB that stated that one of the main reasons for transmission failure is contamination of transmission fluid with antifreeze. As it turns out, my transmission has been overhauled 3 times in the past 2 years and is failing yet again. Time for a new radiator. Thanks a bunch for your advice.Get new transmission cooler lines as well. The lines tend to hold contaminents will kill new transmissions. Link to comment Share on other sites More sharing options...
Charles G Posted May 7, 2009 Author Report Share Posted May 7, 2009 Get new transmission cooler lines as well. The lines tend to hold contaminents will kill new transmissions.Thanks, I hadn't though of that. :) Link to comment Share on other sites More sharing options...
erikv11 Posted May 17, 2009 Report Share Posted May 17, 2009 Let me know if you are looking for a radiator, I am picking up a new-in-box 8602538 Volvo radiator later this week. It may fit the S80 I'm not sure. Anyone who can look up part numbers please chime in. Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 17, 2009 Report Share Posted May 17, 2009 Okay, I guess testing the radiator was a dumb idea. I'll just replace it and save the $50 testing fee. Besides, I just read a Volvo TSB that stated that one of the main reasons for transmission failure is contamination of transmission fluid with antifreeze. As it turns out, my transmission has been overhauled 3 times in the past 2 years and is failing yet again. Time for a new radiator. Thanks a bunch for your advice.AHHHHHH!When those trans. go, replace it aLL , oil cooler, transmission, radiator, lines!!!Instead of it going 1 year down the road you might get 4 lol.... I'm waiting for my tranny to kick it, but i do filters every 20k with synthetic flush..... hope it works. Link to comment Share on other sites More sharing options...
