Guest rpaulson7 Posted May 7, 2009 Report Share Posted May 7, 2009 I cannot find the fuel filter on a 2004 Volvo S60 2.5L turbo. I'm reading that it should be near the passenger side rear wheel, but I am following the fuel line from the tank to the engine and can't find it.Thanks. Link to comment Share on other sites More sharing options...
vegasjetskier Posted May 7, 2009 Report Share Posted May 7, 2009 Here are the VADIS directions. The drawing isn't very good, but it looks like it's just inside the rocker panel:S60FuelFilter2004.pdf Link to comment Share on other sites More sharing options...
303jrodt5 Posted May 7, 2009 Report Share Posted May 7, 2009 Most are back in the right rear are near the R/R wheel. IIRC the newer S60's like yours are in the tank and not replaceable. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 7, 2009 Report Share Posted May 7, 2009 Having an external fuel filter will depend on what type of fuel tank you have. If it's black plastic, it will have an external filter that is replaceable. If it has a metal tank (silver in color) the fuel filter is integrated into the fuel pump. Usually not serviced. Sounds like you may have a metal tank car. Link to comment Share on other sites More sharing options...
Guest renee.allen@k12.sd.us Posted May 8, 2009 Report Share Posted May 8, 2009 I do have a metal tank, yes. So it must be in the fuel pump, huh? And that seems to agree with some documentation for the engine (drawings) I found online.Would that have to be serviced by a mechanic then? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 8, 2009 Report Share Posted May 8, 2009 I do have a metal tank, yes. So it must be in the fuel pump, huh? And that seems to agree with some documentation for the engine (drawings) I found online.Would that have to be serviced by a mechanic then?It is more work than a standard fuel filter but can be done if you have some wrench turning skillz. A heads up though, the filter is only sold with the pump, it is not removable. I think you are going to be floored by the price of that pump. If you are hellbent on replacing it, I will give you some instructions. Link to comment Share on other sites More sharing options...
rpaulson7 Posted May 8, 2009 Report Share Posted May 8, 2009 I had AutoZone run the free diagnostic test today, and there was a message about too much pressure in the fuel line, like excessive pressure. Maybe flooding the engine?? Not sure. I figured the fuel filter was the cheapest fix, so I bought it, and of course couldn't find it to replace it.My car is hesitating/sputtering occasionally at varying speeds and frequency, and often when I punch the gas. Yesterday it stalled as I came to a stop sign. The RPMs just slowly went to 0 and she quit. I already tried some IsoHeet in the gas, and had the mass airflow sensor cleaned. Then I got the diagnostic info today.Any clues? I saw the price of the fuel pump at AutoZone because I asked, about $260. But, they also sold me a fuel filter that isn't the right one, so now I'm not sure if that's the right fuel pump. Does that price sound about like what I need? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 8, 2009 Report Share Posted May 8, 2009 Probably not the right fuel pump. This is something I would purchase from the dealer without question. If you are getting a DTC for fuel pressure issues there may be a number of causes. The first thing I would do is call your local dealer and see if your car is eligible for Recall 181. They can look this up by VIN # so have it handy. It is for the fuel pressure sensor which is located on the fuel rail. I think it effected 03-05 s60's (not 100% positive about the years) Start there and post back tomorrow. Link to comment Share on other sites More sharing options...
MrWinkey Posted May 8, 2009 Report Share Posted May 8, 2009 Probably not the right fuel pump. This is something I would purchase from the dealer without question. If you are getting a DTC for fuel pressure issues there may be a number of causes. The first thing I would do is call your local dealer and see if your car is eligible for Recall 181. They can look this up by VIN # so have it handy. It is for the fuel pressure sensor which is located on the fuel rail. I think it effected 03-05 s60's (not 100% positive about the years) Start there and post back tomorrow.I believe there was an extensive post on this somewhere before....I think Mike had these issues not sure? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 8, 2009 Report Share Posted May 8, 2009 I believe there was an extensive post on this somewhere before....I think Mike had these issues not sure?linkage? Link to comment Share on other sites More sharing options...
rpaulson7 Posted May 8, 2009 Report Share Posted May 8, 2009 Wow, thanks for the input. I will make that call tomorrow.You people are fast and knowledgable (I think) on here, gonna have to make some more visits. Link to comment Share on other sites More sharing options...
MrWinkey Posted May 8, 2009 Report Share Posted May 8, 2009 Wow, thanks for the input. I will make that call tomorrow.You people are fast and knowledgable (I think) on here, gonna have to make some more visits.Welcome to Volvospeed....Do not look at the man behind the green curtain..... ;) Link to comment Share on other sites More sharing options...
rpaulson7 Posted May 8, 2009 Report Share Posted May 8, 2009 I found out that my car IS eligible for the 181 recall. I have an appt at the dealership for Tuesday next week. I will let you know if that solves the problem, for your reference.Thanks for the help. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 8, 2009 Report Share Posted May 8, 2009 I found out that my car IS eligible for the 181 recall. I have an appt at the dealership for Tuesday next week. I will let you know if that solves the problem, for your reference.Thanks for the help.Excellent, I think that will solve your issue. Keep us posted. Link to comment Share on other sites More sharing options...
rpaulson7 Posted May 14, 2009 Report Share Posted May 14, 2009 Excellent, I think that will solve your issue. Keep us posted.I had the recall work performed on Tuesday, and it seems to have fixed my problem. I haven't felt the engine hesitation at all in about 2 days of driving, and previously it had been happening every time I drove the car. The dealership showed me the letter sent to the service dept. from Volvo, and it mentioned occasional misfiring and unexpected stalls as possible effects, both of which I experienced.Thank you all very much for the help. I would still be chasing this thing down if I hadn't come here, and maybe paid for unnecessary work. Link to comment Share on other sites More sharing options...
