Guest Martijn Posted May 15, 2009 Report Share Posted May 15, 2009 Does anybody have instructions on how to remove the ABS module on my 2004 Volvo S60? I am able to remove the torx screws but am unable to loosed the connection to the fuse box. Anybody have manual? Photo instructions? What is the best place to have it rebuilt? Link to comment Share on other sites More sharing options...
vegasjetskier Posted May 15, 2009 Report Share Posted May 15, 2009 Removal procedure:S60ABSContorlModuleReplacing2004.pdfS60FuseBoxRemoval2004.pdfFor repair service you can contact Vic Rocha: http://home.earthlink.net/~vicrocha/ Link to comment Share on other sites More sharing options...
Martijn Posted May 15, 2009 Report Share Posted May 15, 2009 Removal procedure:S60ABSContorlModuleReplacing2004.pdfS60FuseBoxRemoval2004.pdfFor repair service you can contact Vic Rocha: http://home.earthlink.net/~vicrocha/Victor unfortunately does not do any repairs on my model ABS. Anybody have experience with BBA-reman or Autoecu.com? Link to comment Share on other sites More sharing options...
Young Burnsy Posted May 15, 2009 Report Share Posted May 15, 2009 Are you positive it is the ABS control unit and not one of the wheel sensors? Link to comment Share on other sites More sharing options...
Martijn Posted May 15, 2009 Report Share Posted May 15, 2009 Are you positive it is the ABS control unit and not one of the wheel sensors?Both the dealer as well as a local Volvo-specialist told me it was the module after reading the codes. How much more sure can I be? Link to comment Share on other sites More sharing options...
Young Burnsy Posted May 15, 2009 Report Share Posted May 15, 2009 Both the dealer as well as a local Volvo-specialist told me it was the module after reading the codes. How much more sure can I be?No good, I just wanted to make sure. Because I had my ABS unit replaced when it ended up being one of the wheel sensors. Link to comment Share on other sites More sharing options...
Martijn Posted May 15, 2009 Report Share Posted May 15, 2009 No good, I just wanted to make sure. Because I had my ABS unit replaced when it ended up being one of the wheel sensors.Any suggestions? Link to comment Share on other sites More sharing options...
Young Burnsy Posted May 15, 2009 Report Share Posted May 15, 2009 Any suggestions?If the dealer read the code I'd assume they would be correct. I think my issue was the fact that I went to the indy who didn't have the diag tools that a dealer would. This was before I really knew anything about my car. Link to comment Share on other sites More sharing options...
MrWinkey Posted May 15, 2009 Report Share Posted May 15, 2009 If your car has DSTC ..BBA cannot fix it either ......your at the mercy of the dealer. Link to comment Share on other sites More sharing options...
Martijn Posted May 16, 2009 Report Share Posted May 16, 2009 If your car has DSTC ..BBA cannot fix it either ......your at the mercy of the dealer.I just have STC. Same bad news? Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 16, 2009 Report Share Posted May 16, 2009 i dont know if they can, as the 04 is a computer module (no longer abs module, BCM now)it's an expensive little bugger... why are they calling the bcm, what issues were u having Link to comment Share on other sites More sharing options...
Martijn Posted May 16, 2009 Report Share Posted May 16, 2009 i dont know if they can, as the 04 is a computer module (no longer abs module, BCM now)it's an expensive little bugger... why are they calling the bcm, what issues were u havingABS, Brake light on with "Brake Failure, Stop Safely" warning most of the time. Trip meter goes blank once in a while. Cruise control switches off. Resets sometimes after driving for a while and restarting the engine, but comes messages/lights come back after sitting idle for while. Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 16, 2009 Report Share Posted May 16, 2009 you're whole cluster goes completely dead or just a certain part of the cluster? Link to comment Share on other sites More sharing options...
Martijn Posted May 16, 2009 Report Share Posted May 16, 2009 Most of the times it's the Brake failure, warning. Once in a while it's the other messages, usually in addition to the brake failure messageWould a rebuilt one like this one (see link) from Programa work? Would it need reprogramming?http://tinyurl.com/pdunjq Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 16, 2009 Report Share Posted May 16, 2009 nope.that's still just a plain jane abs unit and not a BCMB5234T3 transmission: A & M up to 2001 --------------------------------------------------------------------------------B5244S transmission: A & M up to 2001 Link to comment Share on other sites More sharing options...
