Martijn Posted May 16, 2009 Report Share Posted May 16, 2009 So, I guess I'll just take a vote from users/readersA. Hope that BBA can rebuild, so send to them B. Buy used C. Buy new ($$$) Thoughts?Any suggestions, other options, tips are welcome! Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 16, 2009 Report Share Posted May 16, 2009 if you buy used you'll have to get it programmed at the dealer. For the price of a new one, you'll most likely never replace it again. Used one may never break.It's up to you, but you have to make sure if you get used, the BCM has to be identical to your car (DSTC/STC, AWD / FWD, etc.)I'd go used. Link to comment Share on other sites More sharing options...
mastertech Posted May 20, 2009 Report Share Posted May 20, 2009 2002 and up ABS units are our hottest seller along with the non-contacting ETM. If we upgrade your existing ABS unit, no software reload will be necessary. We can also supply you with an exchange unit, but you will need to have software reload done. http://xemodex.com/xemodex_011.htm Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 21, 2009 Report Share Posted May 21, 2009 PMed you mastertech ;) Link to comment Share on other sites More sharing options...
Martijn Posted May 25, 2009 Report Share Posted May 25, 2009 2002 and up ABS units are our hottest seller along with the non-contacting ETM. If we upgrade your existing ABS unit, no software reload will be necessary. We can also supply you with an exchange unit, but you will need to have software reload done. http://xemodex.com/xemodex_011.htm How much do you charge for upgrading/rebuilding? (my part# is 8671224; did not see it listed on your website) Link to comment Share on other sites More sharing options...
Martijn Posted May 27, 2009 Report Share Posted May 27, 2009 Removal procedure: S60ABSContorlModuleReplacing2004.pdf S60FuseBoxRemoval2004.pdf For repair service you can contact Vic Rocha: <a href="http://home.earthlink.net/~vicrocha/" target="_blank" rel="nofollow">http://home.earthlink.net/~vicrocha/</a> How do I remove the air cleaner housing? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 27, 2009 Report Share Posted May 27, 2009 How do I remove the air cleaner housing? Remove the fresh air hose where it connects to the MAF. If it is a little difficult to pull off you can use a hair dryer to heat it lightly and it will be easier to pull apart. After they are separated, pull the air box straight up, it just snaps in place. Link to comment Share on other sites More sharing options...
vegasjetskier Posted May 27, 2009 Report Share Posted May 27, 2009 How do I remove the air cleaner housing? S60AirCleanerRemoval2004.pdf Link to comment Share on other sites More sharing options...
Martijn Posted June 18, 2009 Report Share Posted June 18, 2009 I replaced the BCM with a used one. Now I have a new message "anti-skid service required'. No ABS, Brake lights on. Code read is p0076. Any ideas? Link to comment Share on other sites More sharing options...
Chad H Posted July 12, 2009 Report Share Posted July 12, 2009 I'm pretty sure the 04's didn't have the same abs module troubles as the earlier volvo's. Link to comment Share on other sites More sharing options...
