eggman1945 Posted May 16, 2009 Report Share Posted May 16, 2009 Get bulb failure dipped beam - I have checked all fuses and tried swapping the turn signal and light switch new lamps but no voltage at the low beam connectors. My next guess is the relay located behind an access panel - now not sure how to test a relay or which relay is related to the low beam. HELP!ThanksFrank Link to comment Share on other sites More sharing options...
MrWinkey Posted May 16, 2009 Report Share Posted May 16, 2009 Have you looked at your headlamps??? Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 16, 2009 Report Share Posted May 16, 2009 there should be multiple fuses for your headlights. Both aren't working? Link to comment Share on other sites More sharing options...
