Volvoman37 Posted November 6, 2004 Report Share Posted November 6, 2004 alright, after picking up my lovely lovely '95 855T today, i noticed a few things and if anyone knows about em, i'd appreciate some help, as i'm totally new to these cars. the 1990 240DL i had wasnt nearly as advanced technologically1) one of the lights in the dash is out. in the bottom part with my digital clock and temp gauge/other stuff. how do i change it?2) my service light is blinking constantly, ive read that they stay on for a few minutes, but this one doesnt go away. is there a reset button somewhere in the dash? or do i need to take it to volvo?3) the 6 disc changer seems to skip a lot. is this a common problem? i read the article about puting in an aftermarket head unit, which i might end up doing, as i already have a brand new one i had for the 240.4) torque steer is fun thanks guys! Link to comment Share on other sites More sharing options...
theunderlord Posted November 7, 2004 Report Share Posted November 7, 2004 2) my service light is blinking constantly, ive read that they stay on for a few minutes, but this one doesnt go away. is there a reset button somewhere in the dash? or do i need to take it to volvo?←http://volvospeed.com/850slight.htm Link to comment Share on other sites More sharing options...
Guest Guest Posted November 7, 2004 Report Share Posted November 7, 2004 http://volvospeed.com/850slight.htm←sweet! worked the first try. thanks a bunch Link to comment Share on other sites More sharing options...
theunderlord Posted November 7, 2004 Report Share Posted November 7, 2004 sweet! worked the first try. thanks a bunch←No prob man.. check out the repair/maintenance part of VS... very valuable info in the Bay 13 portion.. Rich helps us all out... Link to comment Share on other sites More sharing options...
Volvoman37 Posted November 7, 2004 Author Report Share Posted November 7, 2004 weird. as soon as i started the car this morning, the blinking service light was back on again. i turned it off, put the key to position II, and repeated the process, and the light went off. i took the key out, and restarted it. hello service light, back on again. repeated the process, except this time i turned the car on WITHOUT removing the key. it started and the light stayed off, but as soon as i put the car in gear and started driving, the light came BACK on.and i waited the 2 minutes each time i started it to make sure it wasnt gonna go off on its own.all i can find in the manual for that light is that its just a scheduled maintenence light, and doesnt really signify anything terribly urgent, so why does it keep coming on? thanks again for the help! Link to comment Share on other sites More sharing options...
theunderlord Posted November 8, 2004 Report Share Posted November 8, 2004 so why does it keep coming on? ←pretty much to annoy us.... :D Link to comment Share on other sites More sharing options...
Volvoman37 Posted November 8, 2004 Author Report Share Posted November 8, 2004 pretty much to annoy us.... ←so is there a way to disable it? or should i just go in and take out the bulb?maybe i can use it to replace the one that doesnt work in the temp gauge/mpg thing.... Link to comment Share on other sites More sharing options...
theunderlord Posted November 8, 2004 Report Share Posted November 8, 2004 so is there a way to disable it? or should i just go in and take out the bulb?maybe i can use it to replace the one that doesnt work in the temp gauge/mpg thing....←Well, In my car there is a tool that you have to use to turn off the light, which a buddy of mine has, so it's no big deal. However, what I would do if I were you is just take the bulb out... if you need to be reminded to change your oil and check your air filter, you're a puetz. (which I'm sure you're not ) Take the bulb out, and you'll be good to go. :B Link to comment Share on other sites More sharing options...
The Reverend Posted November 8, 2004 Report Share Posted November 8, 2004 I am such a puetz. Link to comment Share on other sites More sharing options...
theunderlord Posted November 8, 2004 Report Share Posted November 8, 2004 I am such a puetz.←? Link to comment Share on other sites More sharing options...
tboyko Posted November 8, 2004 Report Share Posted November 8, 2004 1) one of the lights in the dash is out. in the bottom part with my digital clock and temp gauge/other stuff. how do i change it?i get this problem as well, and sometimes it just comes back on and then goes out again. any ideas with this guys? it generally comes on or goes out when i turn on my car, not randomly while i'm driving around.... Link to comment Share on other sites More sharing options...
fromtheshadows Posted November 15, 2004 Report Share Posted November 15, 2004 Ive got the exact same problem. i wouldnt worry about it. if your cars obdII you can turn it off. I just havent gotten around to it. If you dont have a scanner you could just put some electrical tape over it and probably get a cool orange glow around it ;) Link to comment Share on other sites More sharing options...
jross Posted November 15, 2004 Report Share Posted November 15, 2004 2) my service light is blinking constantly, ive read that they stay on for a few minutes, but this one doesnt go away. is there a reset button somewhere in the dash? or do i need to take it to volvo?←Try throwing this out in the FWD Maint forum. I'm sure Rich can give you a good solution. Link to comment Share on other sites More sharing options...
