2001T5 Posted May 17, 2009 Report Share Posted May 17, 2009 P0442 = EVAP Emission Control System Leak, or so the OBD2 says. So what exactly should I be focusing on? I'm ordering new turbo hoses and vac hoses tomorrow. Anything else I should add to the list for this? Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 17, 2009 Report Share Posted May 17, 2009 V70... check your J hose check your gas cap and if all looks good bring it to the dealer for an extended warranty (ecm upgrade). Possible bunk leak diag pump. Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 17, 2009 Report Share Posted May 17, 2009 Check the gas cap to make sure it is secure and also inspect the seal for any damage. You can visually inspect the hoses by the charcoal canister to see if there are any obvious breaks in them as well. Evap leaks are more easily diagnosed with things like smoke machines. Link to comment Share on other sites More sharing options...
MrWinkey Posted May 17, 2009 Report Share Posted May 17, 2009 Your turbo and vac hoses have nothing to do with it. Follow your lines from the fuel tank up and inspect thoroughly (not the fuel feed and return either). Link to comment Share on other sites More sharing options...
2001T5 Posted May 21, 2009 Author Report Share Posted May 21, 2009 Just got the new gas cap in today. There is almost a half inch difference in where the seal sits. The old seal is so far up in the knob that you can barely put a finger on it. The new one sits outside the knob. I haven't cleared the code yet, but can tell just visually that this could be the problem. I also inspected the lines from the gas fill area. All look okay, up until they go underneath the rear suspension. I can't look any further until I get it on a lift. Thanks for the help!! Link to comment Share on other sites More sharing options...
MrWinkey Posted May 21, 2009 Report Share Posted May 21, 2009 OEM gas caps work best....Just buy the one without instructions on how to install as it's cheaper....seriously :o Link to comment Share on other sites More sharing options...
2001T5 Posted May 22, 2009 Author Report Share Posted May 22, 2009 It was only 28 bucks, so not too bad. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted May 22, 2009 Report Share Posted May 22, 2009 i got the same code i went through the vac system and all the usual things and it still comes back. my next step is the vac lines near the gas tank. Link to comment Share on other sites More sharing options...
Martynj Posted May 22, 2009 Report Share Posted May 22, 2009 I got the same code too in January and replaced the gas cap and it's been fine since. OEM cap all the way. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted May 23, 2009 Report Share Posted May 23, 2009 I got the same code too in January and replaced the gas cap and it's been fine since. OEM cap all the way. i replaced my cap with an oem one twice and still get the code. last time i was under the cari remember seeing frayed vac lines near the FPR and the vent lines near the tank, im gonna replace them soon. Link to comment Share on other sites More sharing options...
