eslovett Posted May 21, 2009 Report Share Posted May 21, 2009 99 S70 with 122K miles. I changed the oil trap and stopped the oil leaks. Now I have antifreeze leaking into the oil pan. When changing out the oil trap, I noticed there was a connection under the left side of the Air Intake Manifold. This connection is a junction of three hoses; two from the breather hose and one going to a connection near the thermostat (and thus antifreeze). First: Can anyone tell me what this line is that is going towards the thermostat? Second: Why am I getting antifreeze through the oil trap and into the oil? Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 21, 2009 Report Share Posted May 21, 2009 only way coolant can go into the oil pan from the pcv is if the nipple for the pcv is cracked. Link to comment Share on other sites More sharing options...
AlvinL Posted May 21, 2009 Report Share Posted May 21, 2009 only way coolant can go into the oil pan from the pcv is if the nipple for the pcv is cracked. Can you elaborate? Link to comment Share on other sites More sharing options...
PsychoWagon Posted May 21, 2009 Report Share Posted May 21, 2009 theres a metal pcv nipple on 99s. It has to coolant lines coming off of it, and a thin line that goes to the pcv... if somehow both parts of the metal cracked then it would make it to the oil pan. <- highly unlikely. Unless you ptu a water line on where a pcv hose should go your car has other problems :o Link to comment Share on other sites More sharing options...
MrWinkey Posted May 21, 2009 Report Share Posted May 21, 2009 Why do you state it's antifreeze? Are you sure it's not just condensation which is very common? Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 22, 2009 Report Share Posted May 22, 2009 Why do you state it's antifreeze? Are you sure it's not just condensation which is very common? I am curious of this as well. DId you drain oil the oil from the pan to find milky oil or did you pull the dipstick and find a milky substance? Link to comment Share on other sites More sharing options...
