Guest dguillot Posted May 26, 2009 Report Share Posted May 26, 2009 Code: [P1671] CMP Actuator Performance Problem Or Signal Out Of Range ----------------------- The check-engine light comes on and stays on continually, until the computer is reset with battery cable removal. The battery cable removal reset only keeps the light off for 7 miles, only after the car has sat for 4 plus hours. A Scan Tool resets the light for only a few seconds. After the car runs a while and the engine light comes on, a battery cable removal to clear the computer, gives the result of only 1 minute of run time before light comes on again. Any ideas, could it be the sensor, the actual cam actuator or alignment of the stars? I had the timing belt change at Volvo of Houston in Jan. of 2009. I ask them to read and clear the computer at that time but they stated that, the cause of the engine light was a leaky radiator resevoir, and since I had one to replace it with, go ahead and change that first. I did and problem still existed. Adding this ODBII chart that I found on the Internet from INNOVA Volvo ODBII Codes.txt Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted May 26, 2009 Report Share Posted May 26, 2009 Likely it's just the cam position sensor has gone bad. this is a very easy replacement and the average DIYer should be able to tackle this job. Link to comment Share on other sites More sharing options...
NWC70 Posted May 26, 2009 Report Share Posted May 26, 2009 Just as a side note, if your timing is off that will throw the same code as if the sensor is really out. Link to comment Share on other sites More sharing options...
