gr8gatzby Posted May 31, 2009 Report Share Posted May 31, 2009 The 850 started acting up, and i'll try to explain it the best i can. all will be working well and all of the sudden four things will happen simultaneously: ABS light comes, i lose all lighting including headlights, cruise control disabled, and turn signals wont work. i remedy this by shifting to neutral and power cycling the car, then shift back to drive. any ideas? Link to comment Share on other sites More sharing options...
troyhyde Posted May 31, 2009 Report Share Posted May 31, 2009 Major electrical power drop out. I'd look at the ignition switch and the battery positive cable. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted May 31, 2009 Report Share Posted May 31, 2009 id, check the alt. maybe its on the way south.. Link to comment Share on other sites More sharing options...
speedn_j Posted May 31, 2009 Report Share Posted May 31, 2009 mine does this. its your ignition switch. just click the key back a tad and everything will go back to normal. its when you start the car and the key is rotated to far. Link to comment Share on other sites More sharing options...
S70 Cruiser Posted June 16, 2009 Report Share Posted June 16, 2009 Mine was a full power failure on the highway, but it sounds like yours did what mine did about six months ago, but the switch issues never seemed to play a role for me. I could never reproduce it, and mine has a definite link to my foot engaging the clutch at the same time. I have a new post looking for help now. If you turn off the heater and blower, the lights will not dim as bad and the brown out will not pull your radio to think it was taken out and you should not have to reset it each time. My issues also happened on humid days after the sun came out after a rain or wet snow day - essentially humid in the car. I am thinking it is the ABS/TRAC module in my case, but the switch is a close second. Link to comment Share on other sites More sharing options...
