jschaefer7406 Posted June 15, 2009 Report Share Posted June 15, 2009 Hello all, Just curious to see which actuator is recommended for my 15G swap (2000 S70 AWD). I am leaning toward using the 15G actuator, but is the 13T actuator on the car now better or worse? Also, with only 6-7 psi max, is there any sense trying to source the 300/70 actuator from the 19T? Thanks in advance for any advice, Joe P.S. - I have had some intermittent erratic boost issues with this for about a year now. Sometimes fades @ part throttle, other times it shoots right to 5 and then immediately back to 2, and so on. CBV is new, IPD TCV, all silicone vaccum hoses. This behaviour sort of makes me wonder if maybe the current actuator spring may be weak and allowing the wastegate to leak (is adjusted to 3 psi right now). Thoughts? Link to comment Share on other sites More sharing options...
TryingBe Posted June 15, 2009 Report Share Posted June 15, 2009 Use the 15G actuator. B5234FT TD04HL-15G 150/40 Bosch M4.4 8601238 (Exch) B5234T3 TD04HL-16T 218/60 Bosch ME7x 9471655 B5234T3 TD04HL-16T 275/60 Bosch ME7x 8601691 (Exch) B5234T3 TD04HL-16T 275/60 Bosch M4.3 8601691 (Exch) B5234T4 TD04HL-16T 216/60 Bosch M4.3 1275663 B5234T4 TD04HL-16T 216/60 Bosch M4.3 8601239 (Exch) B5234T4 TD04HL-16T 216/60 Bosch M4.3 8601226 (Exch) B5234T4 TD04HL-18T 275/60 Bosch M4.4 9185628 B5234T4 TD04HL-18T 275/60 Bosch M4.4 8601456 (Exch) B5234T5 TD04HL-15G 150/40 Bosch M4.3 9146785 B5234T8 TD04HL-18T 300/70 Bosch ME7x 9454563 B5234T8 TD04HL-18T 300/70 Bosch ME7x 8601461 (Exch) B5244RT TD04HL-19T 300/70 Bosch ME7x 9471657 B5244RT TD04HL-19T 300/70 Bosch ME7x 8601693 (Exch) B5254T TD04HL-13G 150/30 Bosch M4.4 8601227 (Exch) Link to comment Share on other sites More sharing options...
Spanky Posted June 16, 2009 Report Share Posted June 16, 2009 Use the 15G actuator. B5234FT TD04HL-15G 150/40 Bosch M4.4 8601238 (Exch) B5234T3 TD04HL-16T 218/60 Bosch ME7x 9471655 B5234T3 TD04HL-16T 275/60 Bosch ME7x 8601691 (Exch) B5234T3 TD04HL-16T 275/60 Bosch M4.3 8601691 (Exch) B5234T4 TD04HL-16T 216/60 Bosch M4.3 1275663 B5234T4 TD04HL-16T 216/60 Bosch M4.3 8601239 (Exch) B5234T4 TD04HL-16T 216/60 Bosch M4.3 8601226 (Exch) B5234T4 TD04HL-18T 275/60 Bosch M4.4 9185628 B5234T4 TD04HL-18T 275/60 Bosch M4.4 8601456 (Exch) B5234T5 TD04HL-15G 150/40 Bosch M4.3 9146785 B5234T8 TD04HL-18T 300/70 Bosch ME7x 9454563 B5234T8 TD04HL-18T 300/70 Bosch ME7x 8601461 (Exch) B5244RT TD04HL-19T 300/70 Bosch ME7x 9471657 B5244RT TD04HL-19T 300/70 Bosch ME7x 8601693 (Exch) B5254T TD04HL-13G 150/30 Bosch M4.4 8601227 (Exch) good info ;) Link to comment Share on other sites More sharing options...
--Aaron-- Posted June 16, 2009 Report Share Posted June 16, 2009 Where the eff can we get replacement actuators w/o spending 300 bucks at the dealer?! Link to comment Share on other sites More sharing options...
jschaefer7406 Posted June 16, 2009 Author Report Share Posted June 16, 2009 Aaron, Just for the record, the 19T actuator runs $209.41 with my discount at the local dealer. A little better than $300, but still pricey... Joe Link to comment Share on other sites More sharing options...
gdizzle Posted June 16, 2009 Report Share Posted June 16, 2009 Link to comment Share on other sites More sharing options...
Spanky Posted June 16, 2009 Report Share Posted June 16, 2009 Where the eff can we get replacement actuators w/o spending 300 bucks at the dealer?! I will sell you one for $295 :lol: Link to comment Share on other sites More sharing options...
thelostartof Posted June 16, 2009 Report Share Posted June 16, 2009 Why not talk one of the Vendors here to build and sell ya'll a bracket to use a garret/T3 actuator on a Mitsu setup? They are worlds stronger and cheap as can be. You can even use a 10+ year old stock one off a rwd car and even then it will hold up better than your fancy mitsu actuators. I have been thinking about this as of late and with some new Shop tools coming in we might just be able to build a few if there is any interest Link to comment Share on other sites More sharing options...
randomdude Posted June 16, 2009 Report Share Posted June 16, 2009 ^what would the price be? id be super interested? Link to comment Share on other sites More sharing options...
randomdude Posted June 17, 2009 Report Share Posted June 17, 2009 bump for answer please! Link to comment Share on other sites More sharing options...
--Aaron-- Posted June 17, 2009 Report Share Posted June 17, 2009 Aaron, Just for the record, the 19T actuator runs $209.41 with my discount at the local dealer. A little better than $300, but still pricey... Joe Hmm, is that pretty much readily available to you? I'd really like to upgrade and snatch a fresh actuator. If I do it I want it to be bolt on, although some of the other ones appear to be a bit better. Link to comment Share on other sites More sharing options...
jschaefer7406 Posted June 18, 2009 Author Report Share Posted June 18, 2009 Hmm, is that pretty much readily available to you? I'd really like to upgrade and snatch a fresh actuator. If I do it I want it to be bolt on, although some of the other ones appear to be a bit better. Aaron, As long as it's not on backorder or anything stupid, it's readily available. I had thought about it, but really don't need it for my use. Joe Link to comment Share on other sites More sharing options...
Chilled man Posted June 18, 2009 Report Share Posted June 18, 2009 oh really hmm never thought about that . To the machine shop I GO Why not talk one of the Vendors here to build and sell ya'll a bracket to use a garret/T3 actuator on a Mitsu setup? They are worlds stronger and cheap as can be. You can even use a 10+ year old stock one off a rwd car and even then it will hold up better than your fancy mitsu actuators. I have been thinking about this as of late and with some new Shop tools coming in we might just be able to build a few if there is any interest Link for those ? I will get the made in a day :D Link to comment Share on other sites More sharing options...
randomdude Posted June 18, 2009 Report Share Posted June 18, 2009 what do you mean link? pretty sure hes just talking about one off of a 940 have a bracket made in a day and i will buy it. lostartof said hes workin on it, but if you come up with one quick ill take it. Link to comment Share on other sites More sharing options...
