VolvoRine Posted June 17, 2009 Report Share Posted June 17, 2009 Hi guys, I know this might sound dumb but I just wanted to know how many quarts does the engine takes.....and what kind of oil is recommended (synthetic, blend or conventional?, can i change the kind of oil with no problems if I want to....eg: I use right now blend oil, can i change it to Fully Synthetic with no problems in the long term?? Thnaks Link to comment Share on other sites More sharing options...
kelley_aj Posted June 17, 2009 Report Share Posted June 17, 2009 5 qts. The manual recommends 10w-30, but check for your average temp to determine, I always use synthetic Mobil 1 or Castrol. Link to comment Share on other sites More sharing options...
WindowsBreakerG4 Posted June 17, 2009 Report Share Posted June 17, 2009 5 qts. The manual recommends 10w-30, but check for your average temp to determine, I always use synthetic Mobil 1 or Castrol. On a 940 I think it is 4 unless you drain the oil cooler. In your climate I would run 15/40 otherwise you'll thin the oil too much when you really get on the car in my experience. I like delo 400 http://www.chevrondelo.com/en/deloworldwide/uscanadamexico/default.asp but i don't run synthetic. This oil is good for cleaning all of the crap out of your engine. Link to comment Share on other sites More sharing options...
Three Fat Tigers Posted June 18, 2009 Report Share Posted June 18, 2009 4 Quarts of oil. You can use any type of oil in it. There is a possibility that the synthetic will tend to leak more than normal oil, that is if your seals are old/worn, but over all I doubt you would have any issues. If you are running a turbo: On the low side of the viscosity, I would not run below 10w; on the high end, I would stay away from 50 such as 15w50. So 10/15w30 or 10/15w40; I tend to use Mobil 1 10w40 year round, 22$ in the 5 qt jug from walmart. Then Mann (same as Volvo brand) or Mobile 1 oil filters. Link to comment Share on other sites More sharing options...
