raven_850 Posted June 18, 2009 Report Share Posted June 18, 2009 I pulled this # off the plate near the battery: 854 S1 217329 Is the 217329 the engine code??? Link to comment Share on other sites More sharing options...
Chilled man Posted June 18, 2009 Report Share Posted June 18, 2009 engine code is on the plastic cover on the side of the engine. with out that or the vin every engien looks exaclty the same. Link to comment Share on other sites More sharing options...
raven_850 Posted June 18, 2009 Author Report Share Posted June 18, 2009 Sorry I meant engine serial number, not engine code. The FCP PCV kit has a cutoff after engine serial number 616631, NA PCV kit 1 Since it looks like my serial number is 217329, I should use this kit: NA PCV Kit 2 Is that right??? Thx- Link to comment Share on other sites More sharing options...
jschaefer7406 Posted June 18, 2009 Report Share Posted June 18, 2009 Hello, If you look at the sticker on the timing cover, the engine code and engine serial number (the one you need) will be listed. I have never seen it listed anywhere else on the car, so I would be sure to check the label on the cover before ordering. Good luck, Joe Link to comment Share on other sites More sharing options...
