javadoc Posted June 24, 2009 Report Share Posted June 24, 2009 I echo Neubar's suggestion of the BSC/TCV. Link to comment Share on other sites More sharing options...
mdlimy Posted June 24, 2009 Report Share Posted June 24, 2009 Fyi there may not be coil packs on your dizzy ran car but there is still a coil that can go bad( somethings gotta feed that distributor some fire right?) I say replace the maf and when you do make sure you pull your plugs and clean them. Exhaust smoke, black? Link to comment Share on other sites More sharing options...
Rex Posted June 24, 2009 Author Report Share Posted June 24, 2009 Hi all, No, no smoke at all. The boost solenoid seems to be functioning. I have several T5's for spares and they've all got different looms, solenoids and airflow metres etc! I'm sure this is a fuel issue - the immersed pump sounds like a rusty gate when you flick the ignition on, but as I live in a third world country, the pressure guage still hasn't arrived. If I nurse the throttle she still accelerates well up into the rev range uless I floor it and she barfs. It could also be the coil spark amplifier as someone said - I just don't have another to test, and I'm sure it's silly money at Volvo. Regards, Rex Link to comment Share on other sites More sharing options...
Ipd Posted June 24, 2009 Report Share Posted June 24, 2009 If your fuel pump is howling then you should probably replace it, also sounds like it would be in line with the rest of the symptoms you mentioned. Link to comment Share on other sites More sharing options...
javadoc Posted June 25, 2009 Report Share Posted June 25, 2009 If your fuel pump is howling then you should probably replace it, also sounds like it would be in line with the rest of the symptoms you mentioned. I hope it's not as much of a PITA as it is on the 2000 awd cars. :angry: Link to comment Share on other sites More sharing options...
