Guest Wayne Posted June 28, 2009 Report Share Posted June 28, 2009 Car died twice last night and was able to coast into the driveway the second time. Both times I got the ABS and STC lights first, then the SRS light then the car would stumble and die. Battery is six months old. Car will start and run fine with a charged up battery. I am only getting 11 volts at the battery when I jump it with another car. I am thinking it is either the alternator or voltage regulator- I checked grounds and red cable to fuse panel, cleaned battery connections. I would appreciate any advice. Link to comment Share on other sites More sharing options...
Pauloil Posted June 29, 2009 Report Share Posted June 29, 2009 after you charge up battery and get 11 volts, alt. is bad I put one from o'reilly's in my 95 850 when similar things occured. Link to comment Share on other sites More sharing options...
