harleyhv Posted July 9, 2009 Report Share Posted July 9, 2009 Ok here is the situation. Got a HU-803 with CD changer not working.... a cd got stuck a while back and had to take it apart to remove it... since then, no CD. I mainly use my IPOD for source of music with an FM transmitter... I know, I know... sound could be improved.... a lot however, still appreciate the Dolby Pro-Logic feature of the HU803... and would like to install a sub somehow... I even tried an HU850 as a replacement to find out that the steering wheel controls and backlight are not functional with a 2001... So anyway here are the options that I'm entertaining for the head unit (speakers update = future audio project) Option 1: * replace the Hu803 with the same thing (source => ebay) * install a USA SPec IPDO adaptor http://www.crutchfie...USA+Spec&tp=120 * get a powered subwoofer and the Volvo sub harness * have the HU803's software updated to be able to drive the sub. Option 2: * replace the HU803 with the KD-AVX77 from crutchield.com (with the installation gear package) http://www.crutchfie...7.html?tp=20217 demo http://www.crutchfieldadvisor.ca/S-bFkhcz8dKWO/videos/carstereos/jvc_kd-avx77.html * get a Steering Wheel Audio Control Adapter http://www.crutchfie...CK.html?tp=3405 * get a powered subwoofer and run a connection from the KD-AVX77 * get an amp to power the center front channel Considering the cost involved.... I'm guessing that option 2 would be a little costlier than option 1 but not by much, Option 2 also provides bluetooth integration.... However would Option 2 sound a lot better? Any feedback is welcomed Link to comment Share on other sites More sharing options...
Young Burnsy Posted July 9, 2009 Report Share Posted July 9, 2009 I would say yes, option 2 will sound a lot better. I think the hardest thing to source might be the center channel speaker/amp. I think the deck will handle the sub better. I right now have two Boston G512s attached to the HU-813 and I also have the USA-Spec ipod adapter. The adapter works great how ever there is a good amount of interference noise cause I think by a bad ground, I haven't investigated it yet but the issue can probably be solved by changing the ground and adding a line filter. Also depending on the price of the HU-803s option 2 could and most likely will be much more expensive then option 1. Link to comment Share on other sites More sharing options...
harleyhv Posted July 26, 2009 Author Report Share Posted July 26, 2009 I would say yes, option 2 will sound a lot better. I think the hardest thing to source might be the center channel speaker/amp. I think the deck will handle the sub better. I right now have two Boston G512s attached to the HU-813 and I also have the USA-Spec ipod adapter. The adapter works great how ever there is a good amount of interference noise cause I think by a bad ground, I haven't investigated it yet but the issue can probably be solved by changing the ground and adding a line filter. Also depending on the price of the HU-803s option 2 could and most likely will be much more expensive then option 1. yup after some searching... Looks like center channel amp is indeed the challenge here for option 2 For option 1, finiding a decent price Hu803 would be it. Link to comment Share on other sites More sharing options...
Chilled man Posted July 26, 2009 Report Share Posted July 26, 2009 The Pioneer Dual Din DVD Player I have in my wagon has a center channel amp built in for it . So just buy a headunit that is 5.1 with center channel out put :D Link to comment Share on other sites More sharing options...
harleyhv Posted July 27, 2009 Author Report Share Posted July 27, 2009 The Pioneer Dual Din DVD Player I have in my wagon has a center channel amp built in for it . So just buy a headunit that is 5.1 with center channel out put Agreed. Finding such a dual DIN headunit is somewhat easier.... However, looks my car can't accept dual DIN unit according to Crutchield... 2001-2003 P2 only accept single DIN uit... Link to comment Share on other sites More sharing options...
Young Burnsy Posted July 27, 2009 Report Share Posted July 27, 2009 Agreed. Finding such a dual DIN headunit is somewhat easier.... However, looks my car can't accept dual DIN unit according to Crutchield... 2001-2003 P2 only accept single DIN uit... Crutchfield is wrong. The hu-803 is a dual DIN. All of the Volvo decks are dual DIN. You just need to find a dual DIN dash kit. Link to comment Share on other sites More sharing options...
harleyhv Posted August 9, 2009 Author Report Share Posted August 9, 2009 Crutchfield is wrong. The hu-803 is a dual DIN. All of the Volvo decks are dual DIN. You just need to find a dual DIN dash kit. It seems that you're right. Found a post in V79xc.om identifying the dual DIN faceplate for V70 The Volvo panel is: 9184995 or 9184996 for MY's until 2003 and 8684591 from MY 2004. Optional storage tray: » 9150773 -2003 » 8684594 2004- (listed as charcoal) and the optional cover plate: 9184042 -2003 8684593 2004- (charcoal) Looks it can be order at the dealership. Can someone validate this info? Link to comment Share on other sites More sharing options...
harleyhv Posted August 10, 2009 Author Report Share Posted August 10, 2009 For those interested. Went to the dealership this morning Confirmed * 9184995 is the part number for a double DIN MY's until 2003. It's around 45S (cdn) * 9184996 does not exist anymore. This simplifies things greatly. Link to comment Share on other sites More sharing options...
