jnderr Posted July 9, 2009 Report Share Posted July 9, 2009 Just curious what kinds of methods people used to secure the projector to the reflector/housing for the low beam and still allow for adjustment. Link to comment Share on other sites More sharing options...
NGB Posted July 9, 2009 Report Share Posted July 9, 2009 Drilled 4 holes and ran studs through, held the studs in place using jam nuts. Some people also JB weld the studs into the stock reflector bowl and then bolt the projecter onto those. Link to comment Share on other sites More sharing options...
Ipd Posted July 9, 2009 Report Share Posted July 9, 2009 I mixed MEK and abs shavings, then epoxied it in place for the first one I did. Still holding together pretty well. Link to comment Share on other sites More sharing options...
Oreo931 Posted July 9, 2009 Report Share Posted July 9, 2009 epoxied it in place for the first one I did. Still holding together pretty well. This is what I did on my s70. The projectors have been fine for over 2.5 years now. Link to comment Share on other sites More sharing options...
Serge Posted July 10, 2009 Report Share Posted July 10, 2009 Drilled 4 holes and ran studs through, held the studs in place using jam nuts. Some people also JB weld the studs into the stock reflector bowl and then bolt the projecter onto those. Pretty much. I bought long threaded bolts and cut them to length. Then used nuts and washers to secure it. JB welded the nuts to the reflector housing. Link to comment Share on other sites More sharing options...
jnderr Posted July 10, 2009 Author Report Share Posted July 10, 2009 Thanks for the responses, that gives me a good idea as to how to move forward. Link to comment Share on other sites More sharing options...
TorqueSteer Posted July 10, 2009 Report Share Posted July 10, 2009 I was uncomfortable with using epoxy so I used nuts and springs, so they can be easily adjusted. Link to comment Share on other sites More sharing options...
'93 Dave Posted July 10, 2009 Report Share Posted July 10, 2009 springs are ideal and it helps cushion the projector when u hit bumps jb welding it to the housing is fine, i just want there to be some give on such a small reflector and patience is needed, as it might take a few times to align the beam horizontally. install the projectors then put them on the car without finishing up to make sure its aligned. Link to comment Share on other sites More sharing options...
jnderr Posted July 10, 2009 Author Report Share Posted July 10, 2009 and patience is needed, as it might take a few times to align the beam horizontally. install the projectors then put them on the car without finishing up to make sure its aligned. I think at present its the horizontal alignment that is my biggest concern. That seems like its kind of fixed so you need to get that right before adding bolts or studs. Link to comment Share on other sites More sharing options...
Get Some Posted July 10, 2009 Report Share Posted July 10, 2009 i used jb weld, epoxy and spray foam .. stuffs holdin up real good Link to comment Share on other sites More sharing options...
TorqueSteer Posted July 11, 2009 Report Share Posted July 11, 2009 I think at present its the horizontal alignment that is my biggest concern. That seems like its kind of fixed so you need to get that right before adding bolts or studs. If you use nuts and bolts, there is plenty of adjustment room for horizontal even after the bolts are in place. Link to comment Share on other sites More sharing options...
'93 Dave Posted July 11, 2009 Report Share Posted July 11, 2009 If you use nuts and bolts, there is plenty of adjustment room for horizontal even after the bolts are in place. +1, loosen up the bolts and then you can twist the projector, then when its in the right spot just tighten everything back up. little bit of apoxy and your golden. however there are a few difficulties with certian projectors. mainly ones that arnt symmentrical. ie e55s. because of the switch its not as easy to rotate. Just curious what kinds of methods people used to secure the projector to the reflector/housing for the low beam and still allow for adjustment. and before you cut up the reflectors, put in a bulb turn it on and point it at the wall. mark this point on the wall and on the bench as when you install your projector this is where you want the center of the beam to go! Link to comment Share on other sites More sharing options...
TorqueSteer Posted July 11, 2009 Report Share Posted July 11, 2009 Yeah my E55's were a pain compared to my first retro with the Bosch ones. What are you running now, the E55's or the TSX? Link to comment Share on other sites More sharing options...
'93 Dave Posted July 11, 2009 Report Share Posted July 11, 2009 Yeah my E55's were a pain compared to my first retro with the Bosch ones. What are you running now, the E55's or the TSX? fist tsx --> then e55 -->now tfx(in the works) Link to comment Share on other sites More sharing options...
TorqueSteer Posted July 11, 2009 Report Share Posted July 11, 2009 fist tsx --> then e55 -->now tfx(in the works) What do you think of the E55? Im still getting the aim right, but so far im not too happy with them. Link to comment Share on other sites More sharing options...
