monkito Posted July 10, 2009 Report Share Posted July 10, 2009 Hi every body , have an 1999 s80 t6 with an check engine light,I did repalce the fuel cap and some vacuum hoses by the filter(driver side) and the purge valve(by the radiator) for a couple of days it work ok but the light came back . I took it to my regular machanic and he told me that he replaced some othe vaccum lines and reseted it but it came back again! any othe suggestions any body may have? please need some help, thanks. Link to comment Share on other sites More sharing options...
Guest Guest_Oak Posted July 10, 2009 Report Share Posted July 10, 2009 Hi every body , have an 1999 s80 t6 with an check engine light,I did repalce the fuel cap and some vacuum hoses by the filter(driver side) and the purge valve(by the radiator) for a couple of days it work ok but the light came back . I took it to my regular machanic and he told me that he replaced some othe vaccum lines and reseted it but it came back again! any othe suggestions any body may have? please need some help, thanks. I too would like to know if anybody has any other suggestions as I'm dealing with the same p0442 issue, but I have yet to replace the purge valve or lines. If the purge valve fails, is it closed, opened, or what happens? bad idle? horrible gas mileage. Monkito, are you getting any other codes? Link to comment Share on other sites More sharing options...
monkito Posted July 10, 2009 Author Report Share Posted July 10, 2009 NO AT THIS TIME I HAVE NOT GOT ANY OTHER CODES BUT OTHER SOURCES TOLD ME TO CHEC THE "J" HOSE ON THE CHARCOAL CANISTER? Link to comment Share on other sites More sharing options...
monkito Posted July 20, 2009 Author Report Share Posted July 20, 2009 Finally I got it! that pesky po442 small evap-leak was solved. replaced the j-hose on top of the charcoal canister and the rest the light ,no more codes!!!!! Link to comment Share on other sites More sharing options...
rodrigo Posted August 18, 2009 Report Share Posted August 18, 2009 Finally I got it! that pesky po442 small evap-leak was solved. replaced the j-hose on top of the charcoal canister and the rest the light ,no more codes!!!!! Location of said hose? Link to comment Share on other sites More sharing options...
2001T5 Posted August 19, 2009 Report Share Posted August 19, 2009 Look underneath the car, in the passenger wheel well. I think it's right behind your gas fill tube thingy (<-- tech terms for ya ) Link to comment Share on other sites More sharing options...
rodrigo Posted August 19, 2009 Report Share Posted August 19, 2009 Look underneath the car, in the passenger wheel well. I think it's right behind your gas fill tube thingy (<-- tech terms for ya ) I'm going to look again this evening. Its not by the fuel filter is it? Link to comment Share on other sites More sharing options...
64pvolvo1800 Posted August 19, 2009 Report Share Posted August 19, 2009 I'm going to look again this evening. Its not by the fuel filter is it? it's either in the front of the drivers wheel well or on pass side just in front of the rear wheel/by the wheel. Link to comment Share on other sites More sharing options...
Guest cbf Posted September 4, 2009 Report Share Posted September 4, 2009 it's either in the front of the drivers wheel well or on pass side just in front of the rear wheel/by the wheel. Newbie here with same 442 code. Can an amateur like me replace this hose? maybe monkito can show us step by step procedure. ( thanks monkito) and point out the exact defective hose. I can see at least three hoses down in there, all of them hard to get to. Thanks in advance Link to comment Share on other sites More sharing options...
Ihatespeedbumps Posted September 4, 2009 Report Share Posted September 4, 2009 it's either in the front of the drivers wheel well or on pass side just in front of the rear wheel/by the wheel. No. That is for x70 cars. The canister and J hose are located on top of the rear suspension near the rear muffler. Link to comment Share on other sites More sharing options...
Figawi Posted September 14, 2009 Report Share Posted September 14, 2009 No. That is for x70 cars. The canister and J hose are located on top of the rear suspension near the rear muffler. Is this where it would be on an 04 V70? I have the PO442 and the dealer suggested I replace the Leak Detection Pump, but the J hose might actually be the problem and it's a cheaper solution. Link to comment Share on other sites More sharing options...
2001T5 Posted September 14, 2009 Report Share Posted September 14, 2009 Man it seems like there are a lot of these lately.... http://volvospeed.com/vs_forum/index.php/topic/123027-cel-code-po442-dealer-cel-codes-ecm-404c-ecm-431d/ Man it seems like there are a lot of these lately.... http://volvospeed.com/vs_forum/index.php/topic/123027-cel-code-po442-dealer-cel-codes-ecm-404c-ecm-431d/ Oops... This is easy as long as you have a lift. 1) Remove the exhaust (cat back I think) 2) Remove the heat shield This should give you access to the canister and J hose. Link to comment Share on other sites More sharing options...
rolo5483 Posted October 12, 2009 Report Share Posted October 12, 2009 Man it seems like there are a lot of these lately.... http://volvospeed.com/vs_forum/index.php/topic/123027-cel-code-po442-dealer-cel-codes-ecm-404c-ecm-431d/ Oops... This is easy as long as you have a lift. 1) Remove the exhaust (cat back I think) 2) Remove the heat shield This should give you access to the canister and J hose. I am working on my 2001 V-70XC... i have had this same code P0456 - EVAP Emission Control System Leak (very small) for a long time... The Charcoal Canister is viewable from underneath the car. I have pressed the said J Connection and it seams to click in. Have you actually replaced the entire hose. The Connection at said J hose is made of plastic and i imagine in order to replace the connection point you would have to replace the entire Pvc tube. regards Link to comment Share on other sites More sharing options...
MrWinkey Posted October 13, 2009 Report Share Posted October 13, 2009 Is this where it would be on an 04 V70? I have the PO442 and the dealer suggested I replace the Leak Detection Pump, but the J hose might actually be the problem and it's a cheaper solution. Common failure and you probably need the pump/...however it usually sets a specific code in my experience. Link to comment Share on other sites More sharing options...
rsleepr88 Posted October 18, 2009 Report Share Posted October 18, 2009 I am working on my 2001 V-70XC... i have had this same code P0456 - EVAP Emission Control System Leak (very small) for a long time... The Charcoal Canister is viewable from underneath the car. I have pressed the said J Connection and it seams to click in. Have you actually replaced the entire hose. The Connection at said J hose is made of plastic and i imagine in order to replace the connection point you would have to replace the entire Pvc tube. regards the hose is the one that runs from the charcoal canister to the shutoff valve both of which are above the rear suspension, not the pvc hard plastic tubing. this is a rubber hose and if you just take the exhaust loose from the hangers and let it hang you shouldnt have to take the whole exhaust off to do the job. the hose splits right at the charcoal canister every time. hope this helps Doug Link to comment Share on other sites More sharing options...
