r850glt Posted November 13, 2004 Report Share Posted November 13, 2004 Any interchange that will give me higher amperage ? I have a 95 854 NA auto, aI think i read somewhere the S 80 or XC 90 might work ? Is this true ? What is the output on these alternators compared to stock 850. Planning on installing bigger amp for radio & red top battery also. Link to comment Share on other sites More sharing options...
Bay13 Posted November 13, 2004 Report Share Posted November 13, 2004 The Volvo alternators that are 120 and 130 amp will not fit in the 850. The 100amp alternator sould work just fine for your stero set up. I'll move this to the audio section so they can chime in for pointers like caps to install to help out. Link to comment Share on other sites More sharing options...
JPigg34 Posted November 13, 2004 Report Share Posted November 13, 2004 How many amps do you plan in installing? Link to comment Share on other sites More sharing options...
r850glt Posted November 13, 2004 Author Report Share Posted November 13, 2004 Thanks, i want use one 400 watt amp. Problem is my battery runs down quickly if i leave the radio on while I wash the car. Link to comment Share on other sites More sharing options...
JPigg34 Posted November 14, 2004 Report Share Posted November 14, 2004 Check www.fcpgroton for a rebuilt alternator. I don't see a need for a higher amp alternator. I'm running two amps and I have no problems. But lets see what Bing says about that. Link to comment Share on other sites More sharing options...
prasamin Posted November 14, 2004 Report Share Posted November 14, 2004 I really avoid using my radio with amp on when my car is off...i think that will drain the battery quickly no matter what, especially using a 1000 watt amp and all the neon lighting I have....I'm running on the stock alternator with a red top for my system, with no problems with dimming or anything....but I never use my radio with the car off ....well, anytime I don't really need to atleast! Link to comment Share on other sites More sharing options...
spottieottie Posted November 14, 2004 Report Share Posted November 14, 2004 I really avoid using my radio with amp on when my car is off...i think that will drain the battery quickly no matter what, especially using a 1000 watt amp and all the neon lighting I have....I'm running on the stock alternator with a red top for my system, with no problems with dimming or anything....but I never use my radio with the car off ....well, anytime I don't really need to atleast!←I don't think that with the red top you will have much problem sitting with the volume on your radio on low even with the 1000W amp & neons. Hint, keep your neons off and as long as you're not thumpin your subs the only power you will be using is for those cool neon lights on your amp and your mids and highs. Link to comment Share on other sites More sharing options...
Chris_R Posted November 15, 2004 Report Share Posted November 15, 2004 A higher amp alternator will allow you to run more gear while the car is runing and it will charge your battery a little faster, but that won't prevent it from dying any sooner. For extended car-off playing time you'll need a second battery and a battery isolator. -Chris Link to comment Share on other sites More sharing options...
