MBT Posted July 23, 2009 Report Share Posted July 23, 2009 My car has had a hard time shifting in reverse for the last few months. It literally jumps when I switch into reverse, but then goes just fine. This happens every time with few exceptions (mostly when I roll back in neutral first). Has anyone else had this problem? What's the issue here? How can this be fixed? Thanks, Mike P.S. the car is a '95 850 GLT. Link to comment Share on other sites More sharing options...
D s50r Posted July 23, 2009 Report Share Posted July 23, 2009 My car has had a hard time shifting in reverse for the last few months. It literally jumps when I switch into reverse, but then goes just fine. This happens every time with few exceptions (mostly when I roll back in neutral first). Has anyone else had this problem? What's the issue here? How can this be fixed? Thanks, Mike P.S. the car is a '95 850 GLT. yupp happend to mine a few weeks ago the trans is on its way out time to put a new trans in the car or step up to a turbo volvo Link to comment Share on other sites More sharing options...
--Aaron-- Posted July 24, 2009 Report Share Posted July 24, 2009 Sounds like some permanent damage has been done to the transmission. How's your trans. fluid? If it's dark and/or smells horrible you might try a flush.......flushing isn't a bad idea either way IMO and is unfortunately all that can really be done. You don't roll in Neutral and hit Drive before you completely stop or anything funky like that do you? Link to comment Share on other sites More sharing options...
MBT Posted July 24, 2009 Author Report Share Posted July 24, 2009 Sounds like some permanent damage has been done to the transmission. How's your trans. fluid? If it's dark and/or smells horrible you might try a flush.......flushing isn't a bad idea either way IMO and is unfortunately all that can really be done. You don't roll in Neutral and hit Drive before you completely stop or anything funky like that do you? No, nothing like that. I'll check the fluid and see if there is anything wrong with it. I know it has not been replaced it a while. Link to comment Share on other sites More sharing options...
--Aaron-- Posted July 24, 2009 Report Share Posted July 24, 2009 No, nothing like that. I'll check the fluid and see if there is anything wrong with it. I know it has not been replaced it a while. Cool.....I have a friend that was popping into drive while rolling and not completely stopped and this happened to him, trans. clunks a little when going into D or R as if a motor mount was shot......even after a flush. Like I said whatever's done to the trans. is done. Flushing will only help temporarily avoid the unavoidable. Link to comment Share on other sites More sharing options...
7 VII 7 Posted July 24, 2009 Report Share Posted July 24, 2009 ENGINE MOUNTS!!!! How are the condition of your engine mounts? Upper Torque Rod Firewall Mount Trans to Subframe Mount Crank/Engine Pad Mount to Subframe Link to comment Share on other sites More sharing options...
MBT Posted July 24, 2009 Author Report Share Posted July 24, 2009 ENGINE MOUNTS!!!! How are the condition of your engine mounts? Upper Torque Rod Firewall Mount Trans to Subframe Mount Crank/Engine Pad Mount to Subframe I've replaced all in the past... few years in the past. I guess I'll have to get underneath and find out for myself. However, why would that only happen sometimes and not all the time if it is about the engine mounts? Link to comment Share on other sites More sharing options...
Modus Posted July 27, 2009 Report Share Posted July 27, 2009 Tranny fluid and motor mounts Link to comment Share on other sites More sharing options...
PsychoWagon Posted July 28, 2009 Report Share Posted July 28, 2009 if you need an auto and want to drive to canada ill give you a good price on a good one with 8l synthetic volvo tran fluid :P Link to comment Share on other sites More sharing options...
pwebb Posted July 29, 2009 Report Share Posted July 29, 2009 +1 on the mounts. it can seem like its random... this may be due to the face that the slack allows the drive train to be in various positions... some that cause more noise and shift shock than other times... Link to comment Share on other sites More sharing options...
lkdude Posted July 31, 2009 Report Share Posted July 31, 2009 +1 on the mounts. it can seem like its random... this may be due to the face that the slack allows the drive train to be in various positions... some that cause more noise and shift shock than other times... Does it happen when engine is hot?? mine happen when temp is hot, and noticed that when the it rainy or when engine is cool, the shift is smooth, I added an oit cooler (ATF) , that helped about 90% of the time now. Link to comment Share on other sites More sharing options...
Gage Posted July 31, 2009 Report Share Posted July 31, 2009 yupp happend to mine a few weeks ago the trans is on its way out time to put a new trans in the car or step up to a turbo volvo +1 ive had 2 go out with the same problems Link to comment Share on other sites More sharing options...
yangotang Posted July 31, 2009 Report Share Posted July 31, 2009 This behavior began the downfall of the Auto trans of my yellow in 2000..... Link to comment Share on other sites More sharing options...
