BlackT5-R Posted July 28, 2009 Report Share Posted July 28, 2009 I have some terrible oem speakers. I want to improve the sound system just by replacing speakers. Any direct fit aftermarket speaker suggestions? Thanks! Link to comment Share on other sites More sharing options...
Auburn T5 Posted August 5, 2009 Report Share Posted August 5, 2009 I just recently put some boston acoustic SR65's in the front door. More or less a direct swap. They come with universal mounting rings that you screw into the factory mount and then screw the speaker onto the mounting ring. I haven't gotten to the back doors yet but I am assuming they're the same. I'm not as interested in as high quality back there as I was in the front so I'll basically just shop for as near identical mounting depth as the SR65's have. Link to comment Share on other sites More sharing options...
cheapwagon Posted August 5, 2009 Report Share Posted August 5, 2009 If I could threadjack a quick question in here... Did the 855R's have speakers in the rear pillars? I always thought I had speakers back there until I replaced my lift gate struts. :lol: Link to comment Share on other sites More sharing options...
Platinum850Wagon Posted August 12, 2009 Report Share Posted August 12, 2009 The SR65 is a 6.5" speaker right? Would the factory grills go back on without any problems? Link to comment Share on other sites More sharing options...
Auburn T5 Posted August 12, 2009 Report Share Posted August 12, 2009 yeah they were a drop in replacement. I didn't have any clearance issues with the magnet or the tweeter. The tweeter assembly maybe only pokes out an inch at most. Link to comment Share on other sites More sharing options...
Dave 54 Posted August 12, 2009 Report Share Posted August 12, 2009 If I could threadjack a quick question in here... Did the 855R's have speakers in the rear pillars? I always thought I had speakers back there until I replaced my lift gate struts. Both of my wagon's had em'. yeah they were a drop in replacement. I didn't have any clearance issues with the magnet or the tweeter. The tweeter assembly maybe only pokes out an inch at most. Were you able to use the stock grills? Link to comment Share on other sites More sharing options...
Auburn T5 Posted August 12, 2009 Report Share Posted August 12, 2009 They went in the front doors the grill is part of the big door panel... the panel went back on without any issues so yes they fit under the stock grilles Link to comment Share on other sites More sharing options...
Dave 54 Posted August 12, 2009 Report Share Posted August 12, 2009 But the OP has a 850, little different. Clearance is an issue, esp. in the rear doors. More than likely the tweeter will be touching the grill, which in turn may cause some vibrating of the grill. I currently have this issue from time to time with 6.5" in the rear doors, as when the bass hits it transfers right to the grill as they are in contact with one another. Link to comment Share on other sites More sharing options...
