esnyder Posted July 31, 2009 Report Share Posted July 31, 2009 I just spent an hour trying to figure out the best way to get into the cabin through the engine compartment. I dug around, pulled back carpet, got under the car, got bit by mosquitos, then cursed a little, then surrendered to the message board. What is the EASIEST way to get the power wire from the battery to the amp. Thanks, Ed Link to comment Share on other sites More sharing options...
(n)A-GAME Posted July 31, 2009 Report Share Posted July 31, 2009 For starters, the answer depends on which amp. If you're installing either a 4x40 or 4x50W OEM amp, you don't need to run any cables to the battery. I suspect this does not apply to you though. The best place to run through is down in the driver's side footwell, near the pedals. Look around, there should be a hole in the firewall down there. It might have a rubber grommet inside it, it might not, but that will be your best bet. Or, if you want the super easy (read:lazy) way out, just run the wires down through the front fenders and inside the car through the front door jamb. I wouldn't recommend doing it that way though. Link to comment Share on other sites More sharing options...
esnyder Posted July 31, 2009 Author Report Share Posted July 31, 2009 For starters, the answer depends on which amp. If you're installing either a 4x40 or 4x50W OEM amp, you don't need to run any cables to the battery. I suspect this does not apply to you though. The best place to run through is down in the driver's side footwell, near the pedals. Look around, there should be a hole in the firewall down there. It might have a rubber grommet inside it, it might not, but that will be your best bet. Or, if you want the super easy (read:lazy) way out, just run the wires down through the front fenders and inside the car through the front door jamb. I wouldn't recommend doing it that way though. Link to comment Share on other sites More sharing options...
esnyder Posted July 31, 2009 Author Report Share Posted July 31, 2009 No, this is a aftermarket amp. The only hole I saw with a rubber grommet is the hole for the hood release cable. They really do an amazing job of insulating these cars. Most cars I have owned you can find multiple spots to pass through the firewall. I dont want to try going through the spot with the release cable because it already looks tight, it has a couple of wires passing through with it in wire wrap. The only other thing I saw was right next to the steering assembly there is a spot that looks like it has been covered with a shinny piece of metal about the size of a quarter. I really dont want to drill anything. I figured I was going to install this thing in an hour or two. I guess there is no easy way to get through there. Maybe I am going to have to drill. Link to comment Share on other sites More sharing options...
Jippi 855 GLT Posted July 31, 2009 Report Share Posted July 31, 2009 theres a grommet near the bottom of the brake booster. theres a rubber grommet and a plastic loom. Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 2, 2009 Report Share Posted August 2, 2009 Dont know why I bother with writeups....... http://volvospeed.com/Mods/passenger_firewall_passthrough.html Or use the one shown here: http://volvospeed.com/Mods/boost_gauge.htm Link to comment Share on other sites More sharing options...
esnyder Posted August 3, 2009 Author Report Share Posted August 3, 2009 Found it thanks. That is really sweet that Volvo put that there. I thought it had wires running through it. Now that I could take my time and really get in there I see that it is exactly what I needed. I should of looked in the write ups, before trying the forums, sorry. I dont know why I didnt think it would be there. Link to comment Share on other sites More sharing options...
