mustang Posted July 31, 2009 Report Share Posted July 31, 2009 All, I know this has been discussed before, but has been a while so I thought i'd share my experience. The ABS module on my 2001 S80 finally died and was quoted around $1500 from the local dealer and around $950 by a non-dealer repair shop. This forum indicated a shop in California that can repair them. After some research, emails, and calls, I went with their service. They were able to repair my unit and only took a few days to get it back. I spend about 30 min removing it, and about 15 min putting it back in. The shop gave me good instrucions for both operations. Total bill was $125 + $15 return shipping. I had a good experience and my ABS unit seems to be working well from doing some hard test stops--and no more warning lights. Consider using them *when* your ABS goes out. Check out Victor Rocha (562) 652-3562 http://home.earthlink.net/~vicrocha/ vicrocha@earthlink.net Hope this helps. Link to comment Share on other sites More sharing options...
TaskMule Posted July 31, 2009 Report Share Posted July 31, 2009 All, I know this has been discussed before, but has been a while so I thought i'd share my experience. The ABS module on my 2001 S80 finally died and was quoted around $1500 from the local dealer and around $950 by a non-dealer repair shop. This forum indicated a shop in California that can repair them. I had mine rebuilt at BBA Reman, through eBay, $55, shipped. Lifetime warranty, works as it should. Link to comment Share on other sites More sharing options...
DennisG Posted July 31, 2009 Report Share Posted July 31, 2009 I just received my rebuild back from A.T.E. in Rogersville,Tennessee, on my ABS unit for my 850. Total rebuild and return shipping was $30.00, with lifetime warranty.Works great! Link to comment Share on other sites More sharing options...
Twin Turbo S80 T-6 Posted August 2, 2009 Report Share Posted August 2, 2009 All, I know this has been discussed before, but has been a while so I thought i'd share my experience. The ABS module on my 2001 S80 finally died and was quoted around $1500 from the local dealer and around $950 by a non-dealer repair shop. This forum indicated a shop in California that can repair them. After some research, emails, and calls, I went with their service. They were able to repair my unit and only took a few days to get it back. I spend about 30 min removing it, and about 15 min putting it back in. The shop gave me good instrucions for both operations. Total bill was $125 + $15 return shipping. I had a good experience and my ABS unit seems to be working well from doing some hard test stops--and no more warning lights. Consider using them *when* your ABS goes out. Check out Victor Rocha (562) 652-3562 http://home.earthlink.net/~vicrocha/ vicrocha@earthlink.net Hope this helps. I just went with this guy today also hes nice he did everything in 20 minutes at his house.. Link to comment Share on other sites More sharing options...
michael-s70 Posted August 9, 2009 Report Share Posted August 9, 2009 what tool do i need to remove it? Link to comment Share on other sites More sharing options...
michael-s70 Posted August 11, 2009 Report Share Posted August 11, 2009 you all do know what they do to the module right?.... Link to comment Share on other sites More sharing options...
Rabbit Posted August 11, 2009 Report Share Posted August 11, 2009 Two bad solder joints repaired on the circuit board where the connector goes! :D Link to comment Share on other sites More sharing options...
7 VII 7 Posted August 11, 2009 Report Share Posted August 11, 2009 what tool do i need to remove it? click the link and all will be knowing Link to comment Share on other sites More sharing options...
Guest IRS Posted August 12, 2009 Report Share Posted August 12, 2009 Rich, Are you doing your own marketing again posing as a satisfied customer? All, I know this has been discussed before, but has been a while so I thought i'd share my experience. The ABS module on my 2001 S80 finally died and was quoted around $1500 from the local dealer and around $950 by a non-dealer repair shop. This forum indicated a shop in California that can repair them. After some research, emails, and calls, I went with their service. They were able to repair my unit and only took a few days to get it back. I spend about 30 min removing it, and about 15 min putting it back in. The shop gave me good instrucions for both operations. Total bill was $125 + $15 return shipping. I had a good experience and my ABS unit seems to be working well from doing some hard test stops--and no more warning lights. Consider using them *when* your ABS goes out. Check out Victor Rocha (562) 652-3562 http://home.earthlink.net/~vicrocha/ vicrocha@earthlink.net Hope this helps. Link to comment Share on other sites More sharing options...
DonutsDemise Posted August 19, 2009 Report Share Posted August 19, 2009 Rich, Are you doing your own marketing again posing as a satisfied customer? I just sent mine to him today Link to comment Share on other sites More sharing options...
NGB Posted August 19, 2009 Report Share Posted August 19, 2009 what tool do i need to remove it? E5 Torx http://www.tooloutfitters.net/e5-torx-socket.html Lisle makes a good socket :tup: Link to comment Share on other sites More sharing options...
michael-s70 Posted August 24, 2009 Report Share Posted August 24, 2009 Two bad solder joints repaired on the circuit board where the connector goes! Yep yep. Also that link is bad... Link to comment Share on other sites More sharing options...
TaskMule Posted August 28, 2009 Report Share Posted August 28, 2009 you all do know what they do to the module right?.... Yup. Tried that, it worked for a while, but failed after a few months. Not worth my time to mess with it again, now it's fixed, and lifetime warranty. Money well spent, I say. Link to comment Share on other sites More sharing options...
