Guest needyerhelp Posted August 3, 2009 Report Share Posted August 3, 2009 I bought a used 99V70, got two keys for it. Neither can be fully inserted, but ignition rotates and functions correctly. I cautiously inserted a key-width pointed object, which went fully in. I'm not sure if spraying lubricant can be safely done, and I'm fearful that my steering-wheel will lock while driving (!) if the key should slip out. I need advice, and not from the dealer, who surely has a $olution. Link to comment Share on other sites More sharing options...
mikus Posted August 3, 2009 Report Share Posted August 3, 2009 Ehhh... I can't speak to 1999, but I know in 1998 and earlier cars, once you turn the cylinder past "OFF" it's unlocked regardless if a key is in there or not. Link to comment Share on other sites More sharing options...
Guest needyerhelp Posted August 3, 2009 Report Share Posted August 3, 2009 Ehhh... I can't speak to 1999, but I know in 1998 and earlier cars, once you turn the cylinder past "OFF" it's unlocked regardless if a key is in there or not. Thanks, I guess. This disturbingly means that my car can be stolen with a screwdriver or nailfile--key needed merely for opening the door... And there's no 'chime' warning that the key is in the ignition, either. What about graphite or silicon sprayed in--will that 'short' the electrics ? Link to comment Share on other sites More sharing options...
Guest needyerhelp Posted August 7, 2009 Report Share Posted August 7, 2009 Thanks, I guess. This disturbingly means that my car can be stolen with a screwdriver or nailfile--key needed merely for opening the door... And there's no 'chime' warning that the key is in the ignition, either. What about graphite or silicon sprayed in--will that 'short' the electrics ? Link to comment Share on other sites More sharing options...
Guest needyerhelp Posted August 7, 2009 Report Share Posted August 7, 2009 still 'needyerhelp'. I noticed that my shiftlock override button is stuck in depressed position. Part of my problem?? Link to comment Share on other sites More sharing options...
