macs&volvos Posted August 3, 2009 Report Share Posted August 3, 2009 My buddy's battery died in his 1996 volvo 960 and now his radio says "code". He has what he thought was the radio code, 4325, but all i am getting is EEEE. I have the serial off the top of the radio, which is V0850-H1129180D Does anyone know what the code is. The dealer says we need to bring the car to them to have them put the code in. Link to comment Share on other sites More sharing options...
macs&volvos Posted August 4, 2009 Author Report Share Posted August 4, 2009 Bump. Anyone. Link to comment Share on other sites More sharing options...
AverageVolvo Posted August 5, 2009 Report Share Posted August 5, 2009 Bump. Anyone. Call darrel waltrip volvo. Link to comment Share on other sites More sharing options...
crazykn Posted August 6, 2009 Report Share Posted August 6, 2009 I highly recommend Darell Waltrip for getting the radio code. They did it over the phone for me today and all they needed was the VIN. I called their parts department and they were very friendly about it. Link to comment Share on other sites More sharing options...
Guest earthguy00 Posted August 21, 2009 Report Share Posted August 21, 2009 I highly recommend Darell Waltrip for getting the radio code. They did it over the phone for me today and all they needed was the VIN. I called their parts department and they were very friendly about it. Link to comment Share on other sites More sharing options...
Guest earthguy00 Posted August 21, 2009 Report Share Posted August 21, 2009 What if you already have the code, but tried to input from memory and the result is the radio says "OFF" I have the 4 digit card, but now cannot even input any digits at all. Is there a way to reset the radio so that I am able to input ANY digits? I already tried disconnecting the battery overnight both the negative and positive terminals to no avail. Anyone have an experience like this before? Link to comment Share on other sites More sharing options...
yangotang Posted August 21, 2009 Report Share Posted August 21, 2009 What if you already have the code, but tried to input from memory and the result is the radio says "OFF" I have the 4 digit card, but now cannot even input any digits at all. Is there a way to reset the radio so that I am able to input ANY digits? I already tried disconnecting the battery overnight both the negative and positive terminals to no avail. Anyone have an experience like this before? yep. you need to provide the radio with 3 hours of constant power. this requires holding position 1 on the key for 3 hours. the "OFF" will stay lit for 3 hours, then change to "CODE" to allow you to try to re-enter it. Link to comment Share on other sites More sharing options...
rj240 Posted August 21, 2009 Report Share Posted August 21, 2009 You will have three tries before it goes back to off... If you try with the number you have and it doesn't work...stop. You have the wrong number... Link to comment Share on other sites More sharing options...
Guest earthguy00 Posted August 30, 2009 Report Share Posted August 30, 2009 yep. you need to provide the radio with 3 hours of constant power. this requires holding position 1 on the key for 3 hours. the "OFF" will stay lit for 3 hours, then change to "CODE" to allow you to try to re-enter it. Link to comment Share on other sites More sharing options...
Guest earthguy00 Posted August 30, 2009 Report Share Posted August 30, 2009 yep. you need to provide the radio with 3 hours of constant power. this requires holding position 1 on the key for 3 hours. the "OFF" will stay lit for 3 hours, then change to "CODE" to allow you to try to re-enter it. Thanks mate. I will give this a go tomorrow and see how it goes as I also recently tried taking the radio fuse out overnight etc. and every case scenario one can think of when doing this. It's a mild revelation to get at the very least another crack at resolving this rather then take it to Volvo. THANKS AGAIN for your input. Link to comment Share on other sites More sharing options...
Guest earthguy00 Posted September 1, 2009 Report Share Posted September 1, 2009 Thanks mate. I will give this a go tomorrow and see how it goes as I also recently tried taking the radio fuse out overnight etc. and every case scenario one can think of when doing this. It's a mild revelation to get at the very least another crack at resolving this rather then take it to Volvo. THANKS AGAIN for your input. Finally got a chance to try another method of leaving the key in the 1 position for several hours and upon leaving it in for a good 6 hours IT WORKED! One shot deal. Never thought I'd miss my music that much after a week. Thank you again for the advise. Link to comment Share on other sites More sharing options...
Guest lorenzo Posted September 2, 2009 Report Share Posted September 2, 2009 help for radio code? volvo v70 1998 serial: v00690 w5129037d thk Link to comment Share on other sites More sharing options...
