Fallsey Posted August 4, 2009 Report Share Posted August 4, 2009 hello fellow Volvo owners, i thought i would start a topic for anyone with questions to their installs. I installed 2 12" Rockford Fosgate subs, with 600 watt amp 2 channel amp, as well as Pioneer AVH-P3100DVD Head unit. I also did the bypass for this unit, rather than installing the unit to the Parking brake. future work to be done, are front 2 door speakers will be replaced, and hooked up to the amp, rear 2 deck speakers will be replaced with 6x8" 4ohm speakers run in series to "fake" the 8ohm factory amp. Pioneer head unit installed, a little bit of work needed to do this, made a bracket to hold it in place, and also had to cut the trim piece by 1/8" all around to get to fit. overall clean look. Apple cable is used for hookup to my iphone. I ran the cable down to the first opening in the console, then made a small notch just beside the parking brake to my phone holder, which is epoxied in place. This is the bypass switch for the Pioneer DVD, to watch dvd/some settings while driving. i just really didnt want to hook this up to the ebrake so i took the alternative. works like a charm. installed into one of the spare slot covers. Here is my 2 12" Rockford Fosgate subs, and 600w Sony xplod 4 channel amp. I will be hooking the front speakers up to this soon enough. It isnt a 1000w system, but it hits HARD. i had to eliminate trunk rattle by taking apart trunk lid(plastic) around licence plate and filling empty gaps with dynamat. Link to comment Share on other sites More sharing options...
Chilled man Posted August 4, 2009 Report Share Posted August 4, 2009 I have that same headunit for my 01XC not a fan of the trim kit or the mounting kit for it . I bought some aftermarket ones for it and they should be here sometime this week .... Link to comment Share on other sites More sharing options...
Fallsey Posted August 4, 2009 Author Report Share Posted August 4, 2009 yeah, i know what you mean, mounting kit or lack of one. I had to cut my previous single DIN sleeve, drill holes in the sleeve, then mount it to the head unit. i also had to shave the rails on the factory opening to squeeze that sucker in. it just didnt look good without the trim on it, so i cut it to fit the opening. there is only a little section on the top that can be seen. Link to comment Share on other sites More sharing options...
Sully83 Posted August 24, 2009 Report Share Posted August 24, 2009 Hey Fallsey, First off GREAT setup, i have been eyeing that head unit for my 99S70, but im still running with an older pioneer deck. Just a quick question/clarification about something you mentioned... What were you saying about "fooling the factory amp" by running the back deck speakers in series? I just spent a few hours installing a set of infinity 6x9's and i want to make sure i am running them properly... thanks man, again... AWESOME system! cheers Link to comment Share on other sites More sharing options...
