Jono850 Posted August 9, 2009 Report Share Posted August 9, 2009 Hey guys, looking for some pictures of 6.25" or 6.5" speakers in 850 doors. I'm debating between sticking with 5.25" or going up to the 6.5". Just unsure as to how it will look with the cutting etc. Have any of you guys done it in yours? Comments? Thanks Link to comment Share on other sites More sharing options...
BurgerBob Posted August 9, 2009 Report Share Posted August 9, 2009 Haven't done it, but I wouldn't. Too easy to just put in 5.25" speakers. Are you going to do custom door panels? Link to comment Share on other sites More sharing options...
Jono850 Posted August 10, 2009 Author Report Share Posted August 10, 2009 I'd like to get some bass without having to find room to put a sub. I like my Jetta's setup with 6.5" in the doors + tweeters. Sounds decent for stock. Link to comment Share on other sites More sharing options...
Dave 54 Posted August 10, 2009 Report Share Posted August 10, 2009 I've got a set of Pioneer 6.5 in the rear, had to cut a couple of posts off the grill cover for it fit back on. If your looking for bass you won't get it with 6.5". Get a Infinity basslink for $299, hardly takes up any room. Or you if you have the extra coin you could go with Rockford Fosgate Punch overload for $700, it's just a little bigger sized, not by much. Link to comment Share on other sites More sharing options...
bob850 Posted August 12, 2009 Report Share Posted August 12, 2009 I've got a set of Pioneer 6.5 in the rear, had to cut a couple of posts off the grill cover for it fit back on. If your looking for bass you won't get it with 6.5". Get a Infinity basslink for $299, hardly takes up any room. Or you if you have the extra coin you could go with Rockford Fosgate Punch overload for $700, it's just a little bigger sized, not by much. When you added the 6.5's in the rear doors, did you retain the plastic piece that is glued to the factory speaker? I don't know what it's called, maybe a splash guard of some sort? I'd like to ad 6.5s to try it out but am wondering about that plastic thing attached to the speaker. Link to comment Share on other sites More sharing options...
Dave 54 Posted August 12, 2009 Report Share Posted August 12, 2009 When you added the 6.5's in the rear doors, did you retain the plastic piece that is glued to the factory speaker? I don't know what it's called, maybe a splash guard of some sort? I'd like to ad 6.5s to try it out but am wondering about that plastic thing attached to the speaker. yeah there's acouple of guide posts that I had to snip off, but that was all. Link to comment Share on other sites More sharing options...
bob850 Posted August 12, 2009 Report Share Posted August 12, 2009 yeah there's acouple of guide posts that I had to snip off, but that was all. Are you referring to the speaker cover/grate or the plastic shield behind the speaker? I'm concerned about the shield behind the speaker which protects the speaker from water. Link to comment Share on other sites More sharing options...
Dave 54 Posted August 12, 2009 Report Share Posted August 12, 2009 Are you referring to the speaker cover/grate or the plastic shield behind the speaker? I'm concerned about the shield behind the speaker which protects the speaker from water. Ah I see, nope didn't need to do anything to them. Link to comment Share on other sites More sharing options...
steve s Posted August 12, 2009 Report Share Posted August 12, 2009 get some foam baffles that u stick in the back of the aftermarket speaker u'r getting. should keep most of the moisture from the rain/water that drips down the window out Link to comment Share on other sites More sharing options...
bob850 Posted August 13, 2009 Report Share Posted August 13, 2009 get some foam baffles that u stick in the back of the aftermarket speaker u'r getting. should keep most of the moisture from the rain/water that drips down the window out Do those baffles affect the sound quality? Link to comment Share on other sites More sharing options...
