tcyc1984 Posted August 15, 2009 Report Share Posted August 15, 2009 Hi, I have recently acquired the factory 4x50W amplifier to be installed under the passenger seat. I had a look under the passenger seat and I could find no mounting holes for the amp. I have checked the seat, the rails, and the floor and I'm still unable to figure out where should the amp mount. Can anyone tell me where the holes are, and it will be best if someone can find the pictures of the amp installed. And also, theres a rectangular plastic housing on the wiring harness that has clips to mount onto somewhere, where should I mount the harness? Thank you very much. Alex Link to comment Share on other sites More sharing options...
(n)A-GAME Posted August 15, 2009 Report Share Posted August 15, 2009 I have it down there without any mounts. It doesn't move and is wedged in there pretty tight. I ran my cables up to the stereo through the center console. So, I had them enter between the passenger seat and center console, totally hidden, and then ran them alongside the inside of the console (there is a lot of space in there). Hope that helps, if you want pictures of anything let me know. Link to comment Share on other sites More sharing options...
tcyc1984 Posted August 15, 2009 Author Report Share Posted August 15, 2009 I have it down there without any mounts. It doesn't move and is wedged in there pretty tight. I ran my cables up to the stereo through the center console. So, I had them enter between the passenger seat and center console, totally hidden, and then ran them alongside the inside of the console (there is a lot of space in there). Hope that helps, if you want pictures of anything let me know. Thanks for the input! Since the amp is located under the seat, I know it won't fly all over the places, but I prefer to do it in the proper and more secure way because theres enough rattles underneath the dashboard after running cd changer cable to the back of the car... I want to find some places that I can secure the wiring harness onto. Anyone else have other inputs? Thanks =) Link to comment Share on other sites More sharing options...
