blown_volvo850r Posted August 18, 2009 Report Share Posted August 18, 2009 Last night I drained the fuel tank in hopes that water in the gas was the problem. Unhooked the fuel filter and pumped all the gas out, then went to the Shell station in my g/f's car and got 10 gallons of 93. The idle was slightly better, but was still sloppy and vacuum was only holding at 5 inches or so. I checked every single vacuum hose and was unable to find any tears or leaks. All turbo hosing is healthy and clamped on tightly. I checked the oil after the few minutes I could get it to run and found tiny air bubbles on the dipstick. I realize that there are a lot of things that can cause bubbling in the oil from bad crankcase ventilation and poor pickup seals to a blown headgasket or cracked block. I let everything cool down for an hour or so and rechecked the oil. No bubbles, but when I pulled the filler cap off and shined a flashlight down into the top of the head, I noticed a slightly greenish tint in the oil. Could be coolant, or just the reflection from my flashlight. I also noticed when I changed the plugs that on cylinder 2 (or 4, it was second from the left), the embossing read "B3340 1.1". The injectors were a dark red color as opposed to the bright oranges that were included with my original engine (from the PO who had installed 350cc whites). Also, the '97s use a fuel return line next to the main fuel line. To my knowledge, the stock fuel pressure regulator should have a nipple on it that allows a hose to be run from the FPR to the return line. The fuel rail that was on my new engine (that had 63K miles on it) was completely sealed and did not have any way to reroute fuel to the return line. As much as I'd like to believe the shop who installed my engine got the right engine, I'm questioning whether or not they did. My first motor had "B5234" on the head under the cam cover. I don't know whether or not it had the "T" embossed, but it was a stock '97 850 R engine. I checked the coolant tank and found no traces of engine oil; however I'm not ruling out a blown headgasket. I would change the oil, but even if there was coolant in the oil (without a blown HG), there's no reason it should cause it to barely idle with virtually no vacuum. So, if anyone could give me some more pointers, I'd appreciate it. I'd also like to know what the B3340 1.1 is all about, as well as the different fuel rail and injectors. Link to comment Share on other sites More sharing options...
the commissar! Posted August 18, 2009 Report Share Posted August 18, 2009 2nd from left viewing from front of car is #2 cylinder No cures here but some thoughts... If you only have 5psi vacuum you ought to have a leak in the "system" somewhere. How about the TB? Is the plate closing? On the idle, it sounds like a fuel or air problem but the crappy idle could be causing or at least negatively impacting the vac issue. What about the IAC? Clean that lately? Are air connections really tight? Is IAC running? What about the fuel filter...is it in good condition? Injectors clean? Link to comment Share on other sites More sharing options...
Oreo931 Posted August 18, 2009 Report Share Posted August 18, 2009 Is your intercooler cracked? Link to comment Share on other sites More sharing options...
erikv11 Posted August 18, 2009 Report Share Posted August 18, 2009 can't help much except that on the fuel rail, some 850s have a fuel line with a return system and some don't, that is not a big deal. Link to comment Share on other sites More sharing options...
Zappo Posted August 18, 2009 Report Share Posted August 18, 2009 CBV torn? I wouldn't worry about the green color when you looked under the cap. If coolant was in there, it definately wouldn't be green. I guess I don't have the back story. A shop replaced your engine? Link to comment Share on other sites More sharing options...
blown_volvo850r Posted August 18, 2009 Author Report Share Posted August 18, 2009 CBV torn? I wouldn't worry about the green color when you looked under the cap. If coolant was in there, it definately wouldn't be green. I guess I don't have the back story. A shop replaced your engine? Yes. My HG blew in about 20 places and oil filled the coolant. Since I had previously had a very small coolant leak in the radiator, I was an idiot and used some stop leak in coolant. I learned my lesson on that. But anyway, the stop leak dyed the coolant brown so I didn't know when there was oil in the coolant. The head was off by .015" and the coolant lines through the block were completely sludged up and couldn't be cleared out, so only replacing the head wasn't an option. I did some more research on oil in coolant and coolant in oil and saw some pictures. Definitely isn't coolant in the oil. The bubbly mixture I saw still looked like oil, not like a foamy chocolate milkshake. Plus, there's no oil in the coolant, so for now I'm ruling out a blown HG. I do have a coolant leak, but it's from where I replaced the upper heater hose and it didn't seal up too well in the firewall, which is another problem in and of itself, but it's taking a backseat for now. There WAS water in the tank, and a fair amount. When I drained the tank, I hooked my old fuel filter up to the line, then clamped a siphoning hose to the front of the filter and ran it into a gas can. Once I could no longer get anymore fluids out, I unhooked the filter and drained it. Probably got a half cup of water out. Then I mounted a catch can under the fuel hose and pumped another cup or so out murky brown water out. It didn't fix the problem, but at least I was able to eliminate the water in the tank as the cause of the problem. The injectors are clean (350cc whites), the IAC is cleaned out, and all the IAC hosing seems to be in good shape. When the car was idling and I was poking around under the hood, I did hear a low pitched whistling sound coming from somewhere near the vacuum tree/intake manifold. So even though all the vacuum hoses seemed fine, I'm suspecting a vacuum leak, and a pretty serious one. I've had bad hoses that brought vacuum down to 12-14 inches at idle, but nothing that pulled it down to 3-5 inches. I'm suspecting either the vacuum tree itself is cracked, has a bad seal on the intake manifold, or that the intake manifold is cracked, loose, or has a bad gasket attaching it to the head. I talked to my mechanic in Louisville and he told me to try a few things to eliminate air delivery and fuel delivery. For air deliver, unhook the MAF. If it idles in a closed system, it's the MAF. As soon as I unhooked it and started the engine, it died. Then he recommended spraying ether into the intake manifold to see if it ran okay with direct injection. It didn't, so I ruled out a bad fuel delivery, but I still wanted to clear the water from the tank. When I started the car, it revs up to 1300rpms or so and gets a full 20-21 inches of vacuum. Within a few seconds, the rpms drop to 600-700 and the vacuum pulls back to 3-5psi and holds there as it gets an extremely rough idle and finally dies in a couple of minutes. Like I said, I can hear a very muted, low pitched hissing sound at the TB area of the intake manifold, so I'm gonna pull everything out there and check it. If it ends up being a cracked manifold, no biggie. I still have the ported manifold from my first engine I can install. I'm gonna go out and get started and post up later, hopefully with some good results. It is possible the IAC isn't working, and if that's the case, well then I think that would be the problem. When I took it out it wasn't dirty and there were no hangups, but then again, it might not be working. I have no idea how to check its functionality though. Link to comment Share on other sites More sharing options...
Zappo Posted August 18, 2009 Report Share Posted August 18, 2009 The IAC really only matters when the engine is cold or an accessory kicks on. Once it is warmed up you could pull the plug on it and it should run fine. Maybe the TB isn't bolted down to the manifold tight? Dig around in there and let us know. Link to comment Share on other sites More sharing options...
blown_volvo850r Posted August 19, 2009 Author Report Share Posted August 19, 2009 Well I just got back in. I basically took the entire area around the TB/IAC apart. Removed the vacuum tree, TB, IAC and hoses, fuel rail, etc. I tried to take the intake manifold off to check the gasket but the lower bolt on the passenger side just under the port to cylinder 5 was completely inaccessible, so I retorqued all the other manifold bolts down really well. I compared the TB from my first engine and it had definitely been ported/polished. It also had a TB spacer on it, and I wasn't sure about how that worked. I know with a ported/polished intake manifold, you need a ported/polished TB or a TB spacer, but I have never heard of using both at the same time. Anyway, the TB was shutting fully, so that was not an issue. The TB gasket appeared to be pretty worn around the edges, so I went Advance Auto to get some hi-temp gasket maker. I'll be putting some in tonight and finishing up in the morning. I also noticed the gasket for the vacuum tree was completely worn out, or whatever was used for the gasket was virtually gone. So I'm gonna seal that up really well as well and let it sit overnight with the TB sealant. Is it possible to check the IAC's functionality? I've tried running my car the way it is without the IAC hooked up and it died instantly. I'm wondering if the IAC isn't working, even though the inside piece swivels like normal. Link to comment Share on other sites More sharing options...
Zappo Posted August 19, 2009 Report Share Posted August 19, 2009 Is it possible to check the IAC's functionality? I've tried running my car the way it is without the IAC hooked up and it died instantly. I'm wondering if the IAC isn't working, even though the inside piece swivels like normal. If it wasn't working then there would be no change when you disconnected it. It appears to be the only thing that is keeping your engine running. Link to comment Share on other sites More sharing options...
JordanW Posted August 19, 2009 Report Share Posted August 19, 2009 I'm not a fan personally of the gasket maker for the intake/tb gaskets. In a bind I'd go to the dealer and buy them, they aren't that expensive... even from the dealer. I'd get a new o-ring for the vac. tree too. Link to comment Share on other sites More sharing options...
TRACStar Posted August 19, 2009 Report Share Posted August 19, 2009 Is your intercooler cracked? +1 Same way my car will run if one of the hoses are off. Check intake hose at turbo too. Link to comment Share on other sites More sharing options...
blown_volvo850r Posted August 19, 2009 Author Report Share Posted August 19, 2009 I've double checked all the turbo hosing and it's all in good shape and all the clamps are well tightened. The gasket maker is only temporary until I can get to the dealership and get some new gaskets. I've let it cure all day so I'm gonna go out and start poking around again. I noticed when the car is idling a lot of noise is coming from the IAC, if that means anything. More to come later. Link to comment Share on other sites More sharing options...
blown_volvo850r Posted August 21, 2009 Author Report Share Posted August 21, 2009 Okay, got some slight updates. For starters, the downpipe was not well tightened down to the exhaust flange. Two of the three nuts were loose, and the bottom stud didn't even have a nut on it. The guys that swapped the motor really half-assed the job. Anyway, I put another nut on there, tightened them down really well, then pull the CBV. The diaphram looked fine, but I put a blanking plate over it anyway just to prevent future leakage. Still didn't run. Now, here's the weird part. I unhooked the IAC and started the car. It still had a rough idle, but the boost gauge was reading 18-19 inches of vacuum, and it held there until I reconnected it. As soon as I hooked it back up, the vacuum went back down to 4-6 inches. After several restarts to get the engine to operating temperature, unhooking IAC would cause the motor to stall. Hooking it back up would still read very low vacuum and it would keep the rough idle for a minute or two, then stall. Any conclusions from that? Link to comment Share on other sites More sharing options...
blown_volvo850r Posted August 25, 2009 Author Report Share Posted August 25, 2009 Swapped a functional IAC in today and still did not run. So I bought an OBD II scanner and these are the codes I got. Only three are vehicle specific. P0141 - O2 sensor heater circuit malfunction (bank 1 sensor 1) P0137 - O2 sensor low volts (bank 1 sensor 2) P0131 - ??? P0303 - Cylinder 3 misfire P0301 - Cylinder 1 misfire P0300 - Multiple/random misfires P0304 - Cylinder 4 misfire P0305 - Cylinder 5 misfire P0302 - Cylinder 2 misfire P1507 - ??? P1505 - ??? P0336 - Crankshaft position sensor A CKT range/perf This problem got worse with rain, and an enormous storm with several puddles driven through ended the R's ability to run. When I was under the front end securing the downpipe to the turbo, I noticed a complete sh*t job on the wires going to the front O2 sensor. We're talking wires hanging around with a couple spots of duct tape here and there. I'm wondering if some water got up in there and shorted something out. I'm also concerned about the crankshaft position sensor, although I'm not exactly sure what that code means. If anyone could explain the codes as well as define the three 1-x-x-x codes, I'd appreciate it. Link to comment Share on other sites More sharing options...
Zappo Posted August 26, 2009 Report Share Posted August 26, 2009 P1505 2-2-3 Idle air control (IAC) valve signal opening Low P1507 2-4-5 Idle air control (IAC) valve signal closing Low P0131 2-1-2 Front heated oxygen sensor (HO2S), signal Low Link to comment Share on other sites More sharing options...
