SIAMBLUE Posted August 19, 2009 Report Share Posted August 19, 2009 Does anyone know the flow rate for the compressor on the V70R KKK? as i want to compare it to a 19t which has 500cfm, As it might be my next upgrade if the KKK flows a lot better, Gary. Link to comment Share on other sites More sharing options...
mdlimy Posted August 19, 2009 Report Share Posted August 19, 2009 not sure on the cfm but i think its somewhere around 550cfm, what are your goals for hp? Link to comment Share on other sites More sharing options...
Ipd Posted August 19, 2009 Report Share Posted August 19, 2009 For 04-05 K24 turbo's this should do you. This is actually the other version but the flow characteristics are effectively identical. Link to comment Share on other sites More sharing options...
turbor850 Posted August 19, 2009 Report Share Posted August 19, 2009 Does anyone know the flow rate for the compressor on the V70R KKK? as i want to compare it to a 19t which has 500cfm, As it might be my next upgrade if the KKK flows a lot better K24 is better overall, I don't think there is a set cfm actual flow for the K24 since that turbo is a freak. Here - 19T Compressor - inducer exducer 1.809 - 2.283 Turbine inducer exducer 2.050 - 1.8000 K24 Compressor - 1.770 - 2.400 Turbine 2.322 - 1.968 inducer exducer so the 19T and K24 are close, but not close if you know what I mean. . . if you want more info. I got it . . . Link to comment Share on other sites More sharing options...
Mogatu'r Posted September 4, 2009 Report Share Posted September 4, 2009 chris, what other information do you have about this turbo? pm sent.. Link to comment Share on other sites More sharing options...
turbor850 Posted September 4, 2009 Report Share Posted September 4, 2009 chris, what other information do you have about this turbo? pm sent.. Its a 6 cm^2 housing. The stub shaft is 5.4mm and has extended tip technology. Anything elseeeeeeeeeeeeee ? The compressor wheel is bigger then a Porsche GT2 wheel and I know where to find compressor wheel upgrades :ph34r: Link to comment Share on other sites More sharing options...
SIAMBLUE Posted September 8, 2009 Author Report Share Posted September 8, 2009 Thanks guys, i am running the 19t with a rica custom straight flanged aftermarket downpipe at the moment and 2.5" cat back, so want a little bit more power, just i have an KKK sat here with an angled OBX DP and a full 3" cat back,so there is more potential for the KKK than the 19t, Gary. Link to comment Share on other sites More sharing options...
