sweeedespeed Posted August 19, 2009 Report Share Posted August 19, 2009 Long Story...I was swapping the pioneer deck out of my 97 t5 into my 98XC. I tried to rewire it in, but failed...Then I tried to wire the old one back in and I somehow messed that up. So I have a rats nest and no working radio. Does anybody have a picture of the wiring or some advice? Link to comment Share on other sites More sharing options...
Che'_Moderator Posted August 19, 2009 Report Share Posted August 19, 2009 some advice? At this point I say you need to take it to a shop Link to comment Share on other sites More sharing options...
DHV70 Posted August 19, 2009 Report Share Posted August 19, 2009 i can take a picture of the back of my stereo head if you'd like, but idk how much that would help Link to comment Share on other sites More sharing options...
MyCarIsRed Posted August 19, 2009 Report Share Posted August 19, 2009 http://au.geocities.com/ozbrick850/Radio_Connectors.html http://www.tehnomagazin.com/Auto-radio-car-connector/VOLVO-Car-Radio-Wiring-Connector.htm thats the wiring assignment for the 850 stereos, i think the 98xc is the same. Pioneer lists the pinouts on it's site. If you can't figure out what the outputs on the 98 stereo are based on the 850 and the car/headunit you prolly should call in some help before you fry the HU. What was in the XC beforehand? Link to comment Share on other sites More sharing options...
TRACStar Posted August 20, 2009 Report Share Posted August 20, 2009 Did you buy a harness adapter or did you try to get fancy and splice it straight to the loom? Link to comment Share on other sites More sharing options...
BEJinFBK Posted August 22, 2009 Report Share Posted August 22, 2009 The car side wiring is spread across the two main connectors: Power and dash speakers on the A connector, Speakers on the B connector. (the speed signal is also on the B connector) Use a meter to confirm power first: Constant Power-------Green/Brown x2 = Pins A4 & A12 Switched Power-------Yellow/Violet = Pin A13 Ground---------------Black x 2 = Pins A6 & A14 Illumination---------Pink = Pin A10 (varies with dash lights) Antenna power amp----Blue/White = Pin A3 (VERY important for radio...) Speed Signal---------Yellow/Black = Pin B7 (you probably don't need this) Dash L+ - Red/White = Pin A1 Dash L- - Yellow/White = Pin A2 Dash R+ - Yellow/Green = Pin A7 Dash R- - Green = Pin A8 Door FL+ - Green/White = Pin B4 Door FL- - Green/Brown = Pin B3 Door FR+ - Red/White = Pin B9 Door FR- - Red/Black = Pin B10 RL+ - Brown/White = Pin B2 RL- - Brown/Black = Pin B1 RR+ - Pink/White = Pin B5 RR- - Pink/Black = Pin B6 Dash and doors are connected in parallel. Antenna Connector? Just use the one that fits the Pioneer. The Big One. Now, repeat after me: Always use a wiring adapter! Always use a wiring adapter! Always use a wiring adapter! Link to comment Share on other sites More sharing options...
