Mete Goktepe Posted August 22, 2009 Report Share Posted August 22, 2009 Hello dear friends, I was wondering if any of you know which side is the negative and which side is positive in speaker cables in connector.. for example front speaker cables are red and green. red and green has one green wire with white stripe and another wire with black stripe.. which of these is negative? and positive? thank you.. Link to comment Share on other sites More sharing options...
JCFrieb Posted August 22, 2009 Report Share Posted August 22, 2009 you can thank BEJinFBK for this from the other thread on this page for help. The car side wiring is spread across the two main connectors: Power and dash speakers on the A connector, Speakers on the B connector. (the speed signal is also on the B connector) Use a meter to confirm power first: Constant Power-------Green/Brown x2 = Pins A4 & A12 Switched Power-------Yellow/Violet = Pin A13 Ground---------------Black x 2 = Pins A6 & A14 Illumination---------Pink = Pin A10 (varies with dash lights) Antenna power amp----Blue/White = Pin A3 (VERY important for radio...) Speed Signal---------Yellow/Black = Pin B7 (you probably don't need this) Dash L+ - Red/White = Pin A1 Dash L- - Yellow/White = Pin A2 Dash R+ - Yellow/Green = Pin A7 Dash R- - Green = Pin A8 Door FL+ - Green/White = Pin B4 Door FL- - Green/Brown = Pin B3 Door FR+ - Red/White = Pin B9 Door FR- - Red/Black = Pin B10 RL+ - Brown/White = Pin B2 RL- - Brown/Black = Pin B1 RR+ - Pink/White = Pin B5 RR- - Pink/Black = Pin B6 Link to comment Share on other sites More sharing options...
MyCarIsRed Posted August 22, 2009 Report Share Posted August 22, 2009 That was posted in reponse to a question about the s/v70, the 850 is not the sa CLicky Link to comment Share on other sites More sharing options...
Mete Goktepe Posted August 22, 2009 Author Report Share Posted August 22, 2009 thanks very much I found the answer to my question.. I was right about assuming that the cables with the white stripes are positive... Link to comment Share on other sites More sharing options...
