jaspercize Posted September 11, 2009 Author Report Share Posted September 11, 2009 What code readers work with which models and years? I received my ELMSCAN 5 USB and after a few minor hiccups it works fine. So if you have a 2000 S70 GLT and don't want to look thru all of the hyperbole, the Elmscan5 should work fine for you. Link to comment Share on other sites More sharing options...
Ghost Shadow Posted September 12, 2009 Report Share Posted September 12, 2009 <br />I received my ELMSCAN 5 USB and after a few minor hiccups it works fine. So if you have a 2000 S70 GLT and don't want to look thru all of the hyperbole, the Elmscan5 should work fine for you.<br /><br /><br /><br /> so what does it read and reset? My launch x431 can get into ABS/CCM/SRS/TCU/ECU/KEYLESS/INSTRUMENT on my 99xc70,01 c70, and 02 xc70...this was just the volvo line up. tried it on a merc ml320 1998, 03 honda accord, 05 acura rl, ect ect.....but this was also $2000. How much was it? If there is a scan tool for only the volvos it would be great for under $200. Link to comment Share on other sites More sharing options...
Guest Crito Posted September 12, 2009 Report Share Posted September 12, 2009 I'm keeping my BSR PPC in the S80 at all times now. I was messing around with some stuff and unplugged the cam position sensor so I wouldn't accidentally bust the connector. Threw code ECM-3000 (internal fault) but by that time I had completely forgotten about unplugging it. Car wouldn't start. So I cleared code and she fired right up and I went for a 20 miles drive before I remembered what I had done. I didn't even get a check engine light! I guess the Bosch ECM compensated somehow. Wouldn't rev much over 3000 rpm but it ran. I couldn't believe it. http://www.ppc-diagnostic.com is a steal for US$200. Link to comment Share on other sites More sharing options...
NGB Posted September 12, 2009 Report Share Posted September 12, 2009 For under $200 I'd look into Auto X-Ray. I have their 4000 model and it's excellent on my GM vehicles and Volvos. Features include... * Displays on screen DTCs (Diagnostic Trouble Codes) and code definitions for: o OBD-II generic codes o OBD-II manufacturer specific codes o Upgradeable to display OBD-I codes * Upgradeable to an OBD-I and OBD-II scan tool * Supports multiple trouble code requests: generic codes, pending codes and enhanced codes which are stored in the PCM # Includes EZ-UPDATE AX400-USB * FREE Internet Updates # Upgradeable to higher version scan tool via the Internet # View LIVE sensor data & engine controlled values from vehicle’s on-board computer # Resets Check Engine Light # View Freeze Frame Data # Reads and Displays supported emissions readiness monitor status # Displays supported Vehicle ID Information (VIN#) # O2 sensor readings Link to comment Share on other sites More sharing options...
Ghost Shadow Posted September 12, 2009 Report Share Posted September 12, 2009 <br />For under $200 I'd look into Auto X-Ray. I have their 4000 model and it's excellent on my GM vehicles and Volvos.<br /><br />Features include...<br /><br /> * Displays on screen DTCs (Diagnostic Trouble Codes) and code definitions for:<br /> o OBD-II generic codes<br /> o OBD-II manufacturer specific codes<br /> o Upgradeable to display OBD-I codes <br /> * Upgradeable to an OBD-I and OBD-II scan tool<br /> * Supports multiple trouble code requests: generic codes, pending codes and enhanced codes which are stored in the PCM<br /><br /># Includes EZ-UPDATE AX400-USB<br /><br /> * FREE Internet Updates<br /><br /># Upgradeable to higher version scan tool via the Internet<br /># View LIVE sensor data & engine controlled values from vehicle's on-board computer<br /># Resets Check Engine Light<br /># View Freeze Frame Data<br /># Reads and Displays supported emissions readiness monitor status<br /># Displays supported Vehicle ID Information (VIN#)<br /># O2 sensor readings<br /><br /><br /><br /> can this unit go into the tcu or ecu and reset adaptives? can this unit go into P2 cars and check codes on the CEM or CCM? Link to comment Share on other sites More sharing options...
mrtl321 Posted September 14, 2009 Report Share Posted September 14, 2009 I found this and wondered if anyone knew if it could get into the ecu or any of those "hard to get into" parts on volvos (96-00) since it had a pretty reasonable price. Link Link to comment Share on other sites More sharing options...
wizzard_al Posted September 16, 2009 Report Share Posted September 16, 2009 Too bad it doesn't work for all Volvos. I have a 99 S70, does not work with it, based on their website: Vehicle coverage PPC Diagnostic System works with all Volvo from 2001-2007. Exceptions: S80 1999-2006 works S80 D/D5/TDI 1999-2000 does not work C70 98-05 does not work S/V40 96-04 does not work I have the PPC rig, and it will work for your car. I used it on a friend's XC70, 99 or 00, and it worked fine. Just has to be one of the cars with the ME7 ECU. I.e., drive by wire, no actual throttle cable, but an electrical connection between throttle pedal and the ECU, and then to the ETM. The manual is a bit off because it doesn't mention the S70's or my S60, but they definitely work on these cars. Just 99 or later. Link to comment Share on other sites More sharing options...
bw77 Posted September 16, 2009 Report Share Posted September 16, 2009 I have the PPC rig, and it will work for your car. I used it on a friend's XC70, 99 or 00, and it worked fine. Just has to be one of the cars with the ME7 ECU. I.e., drive by wire, no actual throttle cable, but an electrical connection between throttle pedal and the ECU, and then to the ETM. The manual is a bit off because it doesn't mention the S70's or my S60, but they definitely work on these cars. Just 99 or later. Thanks for the info, yes my car has ME7, drive by wire. Link to comment Share on other sites More sharing options...
TainterRacing Posted November 10, 2009 Report Share Posted November 10, 2009 Does this work? PC Link Thank you very much for any one that can help.] The right link Thank you very much for any one that can help. Link to comment Share on other sites More sharing options...
nyc1dxo Posted November 10, 2009 Report Share Posted November 10, 2009 I bought the exact unit and it works great! I got it cheaper by taking advantage of BING Ebay 10% discount when buying something with BUy It Now option. Link to comment Share on other sites More sharing options...
brick8 Posted November 11, 2009 Report Share Posted November 11, 2009 anyone here tried this one? volvo scanner diagnostic live data 1.3 Link to comment Share on other sites More sharing options...
zxrv40 Posted November 12, 2009 Report Share Posted November 12, 2009 anyone here tried this one? volvo scanner diagnostic live data 1.3 Hi, I am pretty sure this is the same as the thing I bought from here: http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=270469098539 which is one of these: http://www.ilexa.co.uk/content/category/2/2/19 which has been cracked and hacked no doubt. If you have a vehicle listed in Ilexa's Model and System coverage list then I'd guess it'll work for you. I wanted it for my 1999 V70 2.5 non turbo, front wheel drive and it did not work. I've also got a 1997 V40 2.0 non turbo, fwd and it kind of works for that (that vehicle is listed in their guide). That chipset reference sounds very dodgy to me as well, the chipset for OBD tools is usually ELM 327 series. Mine has a couple of very simple RS 232 converters in it. I found this tool to be more frustration than it was worth, however it doesn't cost much and if it is specified for your vehicle it might be worth the effort. Best regards Link to comment Share on other sites More sharing options...
