Gage Posted August 24, 2009 Report Share Posted August 24, 2009 Link to comment Share on other sites More sharing options...
Ozark Lee Posted August 24, 2009 Report Share Posted August 24, 2009 Yes. ...Lee Link to comment Share on other sites More sharing options...
Gage Posted August 24, 2009 Author Report Share Posted August 24, 2009 Yes. ...Lee COOL TY now maYbe i can get my speedo working again i went from an auto to 5speed and have nothing to plugg this in to looks like im gonna have to splice it in to the wheel sensor or the one on the 5speed Link to comment Share on other sites More sharing options...
Gage Posted August 24, 2009 Author Report Share Posted August 24, 2009 Ok so here is the run down on My nonturbo to turbo swap Car: 1994 855 3ecu setup Motor: From a 1996 854 Turbo 2ecu setup Wiring and Fusebox : 1995 854 N/a 2ecu setup When i first got the wagon it was a N/A Auto with a bad trans, Got a 5speed to swap in all went well everything worked then i did my turbo swap the problem i ran in to was that the n/a ecu plugs were the Big style and the turbo ones are small like this now how do i fix this?? i have no other way but to swap out ALL the wiring from the ecu box all the way to the inside of the car to the dash ! No big deal the fuse box unplugs from the dash any way So i pull it all from the 96 and go to put it in the 94 Gasp what the hell another problem the dash plugs are efing different SON OF A B@#$% Like So So i find a 95 with the same plugs as the 94 and put them in . Cheer the car starts now on to finish putting it together...... Now for the first Drive AHHHHH shifts fine, sounds good and strong, all the gauges..... WAIT A SECOND My Speedo dont work Hmmmmmmm ok i have 3 other clusters ill just swap it out 1 hmm nothing 2 nothing 3 nothing WTF SO now im at this point befor i put the turbo in the speedo worked with nothing plugged in to the trans so i start looking at the harness again and find the 94 harness had no plug on the trans and now the 95 harness has this plug So what do you think i should hook this plugg up to the trans wich has a wheel sensor type plug or the DR wheel sensor In short if you are planing on doing a N/a 2 Turbo swap do it in a 96 or newer or make sure you have a FULL 94 Turbo Donor Car Link to comment Share on other sites More sharing options...
Chilled man Posted August 24, 2009 Report Share Posted August 24, 2009 dumb question but in your ecu pic .... that looks like to me one is ECU and the other is TCU ? :blink: Link to comment Share on other sites More sharing options...
Gage Posted August 24, 2009 Author Report Share Posted August 24, 2009 dumb question but in your ecu pic .... that looks like to me one is ECU and the other is TCU ? no i took it apart and put the 96 and the 94 side by side to show the difference if you have ever seen a 94 3 ecu setup all 3 slots have the big holes ill get a bett pic to show what i mean in a little bit Link to comment Share on other sites More sharing options...
