DMoney Posted August 24, 2009 Report Share Posted August 24, 2009 I know I'm new but I don't see how an S70 GLT can be made faster than a S70 T5. Someone care to elaborate? Thanks. :) Link to comment Share on other sites More sharing options...
HtownTurboBrick Posted August 24, 2009 Report Share Posted August 24, 2009 Well it can be faster if you were to upgrade to a T5 tune w/ 16T turbo versus the stock 13C on the GLT. This is because of the higher displacement and higher compression ratio in the GLT. Link to comment Share on other sites More sharing options...
DMoney Posted August 24, 2009 Author Report Share Posted August 24, 2009 Well it can be faster if you were to upgrade to a T5 tune w/ 16T turbo versus the stock 13C on the GLT. This is because of the higher displacement and higher compression ratio in the GLT. Well I'm looking at buying a different car. I've had 2 people tell me go GLT. What are the pros of T5 versus GLT? Link to comment Share on other sites More sharing options...
mdlimy Posted August 24, 2009 Report Share Posted August 24, 2009 t5 is the more commonly built motor, lower compression allows for higher boost levels. the glt has more low end because of the higher compression but lacks the top end power the t5 allows for. It depends on how much money and how much horsepower you are planning on making. Link to comment Share on other sites More sharing options...
ozzimark Posted August 24, 2009 Report Share Posted August 24, 2009 T5 has more total power, GLT has the power sooner. Link to comment Share on other sites More sharing options...
DMoney Posted August 24, 2009 Author Report Share Posted August 24, 2009 T5 has more total power, GLT has the power sooner. I see, I see. OK so if i want torque, I want a GLT. Are there any cool options on T5 that'd I'd be missing out on? Link to comment Share on other sites More sharing options...
bum2kev Posted August 24, 2009 Report Share Posted August 24, 2009 nothing specific. possibly the trip clock. Link to comment Share on other sites More sharing options...
DMoney Posted August 24, 2009 Author Report Share Posted August 24, 2009 you dont have to source a 16t or a t5 ecu S70 T5m it is then! Thanks guys. Link to comment Share on other sites More sharing options...
troyhyde Posted August 24, 2009 Report Share Posted August 24, 2009 The 2.3L engine should be harder to blow up. Link to comment Share on other sites More sharing options...
bum2kev Posted August 24, 2009 Report Share Posted August 24, 2009 i believe the 2.4 lpt and the 2.3 hpt use the same rods and stroke. i think the pistons are just bigger thus have a thinner side wall.... Link to comment Share on other sites More sharing options...
mdlimy Posted August 24, 2009 Report Share Posted August 24, 2009 S70 T5m it is then! Thanks guys. good choice, glt or t5 are both good motors....as long as they have a manual transmission mated to it ;) Link to comment Share on other sites More sharing options...
Mesoam Posted August 25, 2009 Report Share Posted August 25, 2009 t5's have thicker blocks IIRC as well as sodium filled valves and a slew of other small things Link to comment Share on other sites More sharing options...
Chilled man Posted August 25, 2009 Report Share Posted August 25, 2009 t5's have thicker blocks IIRC as well as sodium filled valves and a slew of other small things only difference is block thickness and .1 more displacement valves are the same your thinking turbo vs NA Link to comment Share on other sites More sharing options...
Young Burnsy Posted August 25, 2009 Report Share Posted August 25, 2009 No boost gauge on the lpt? Link to comment Share on other sites More sharing options...
bum2kev Posted August 25, 2009 Report Share Posted August 25, 2009 no boost gauge on either. Link to comment Share on other sites More sharing options...
