Matty Moo Posted August 29, 2009 Report Share Posted August 29, 2009 I searched, but couldn't come up with anything. I'm swapping out ecu's today. Do I disconnect the battery before doing it, or is it not necessary? Conventional thinking would tell me to disconnect it, but I'm not sure. thanks. Link to comment Share on other sites More sharing options...
DHV70 Posted August 29, 2009 Report Share Posted August 29, 2009 nope, you're good just popping it out and back in again. You disconnect the battery when working on the car to avoid tripping ecu codes (or getting shocked / having an airbag blow up in your face.) You can't trip a code if your there's nothing to read it Link to comment Share on other sites More sharing options...
Matty Moo Posted August 29, 2009 Author Report Share Posted August 29, 2009 thanks. Link to comment Share on other sites More sharing options...
DHV70 Posted August 29, 2009 Report Share Posted August 29, 2009 btw, what are you swapping in? only asking because your sig says its all stock... is it seriously platinum? :blink: Link to comment Share on other sites More sharing options...
Matty Moo Posted August 29, 2009 Author Report Share Posted August 29, 2009 it's a platinum edition wagon. I bought it in may after my other 850 was destroyed by a deer. I couldn't pass the platinum up, as the price was right and the PO was meticulous about maintenance. If the dealer told him it needed replaced, it was done, so it came with all the stage zero stuff already taken care of. all I had to replace were the strut mounts and a control arm, but did the whole front end since I was already in there. I'm swapping in a bsr stage one ecu, but only for a day or two. I'm trying to decide if i want to leave it the way it is, or do more with it. I tend to drive conservatively, but wouldn't mind the extra go. Link to comment Share on other sites More sharing options...
DHV70 Posted August 29, 2009 Report Share Posted August 29, 2009 it's a platinum edition wagon. I bought it in may after my other 850 was destroyed by a deer. I couldn't pass the platinum up, as the price was right and the PO was meticulous about maintenance. If the dealer told him it needed replaced, it was done, so it came with all the stage zero stuff already taken care of. all I had to replace were the strut mounts and a control arm, but did the whole front end since I was already in there. I'm swapping in a bsr stage one ecu, but only for a day or two. I'm trying to decide if i want to leave it the way it is, or do more with it. I tend to drive conservatively, but wouldn't mind the extra go. deer. i had one literally run into my car. It took 4 hours to buff out the hair and blood. and we should all be so lucky to have dealer maintained platinum edition cars. the best of luck with your ecu! try opening her up on the highway.. just once :) Link to comment Share on other sites More sharing options...
