Bazarvospeed Posted September 2, 2009 Report Share Posted September 2, 2009 Here I gots a lighted dome light kit available. If you want lighted icons for your over head dome light ....here is one! This is the gray kit , as found in the S70's. This will work for both 850 & S70. Those with the 850's this kit will be gray , but good news I got the map light covers as well to have your buttons matching up. here's whats in the kit is pictured : Buttons , wiring harness , map light housings , map light cover panels. EVERYTHING except the actual dome light assembly. You EVEN get the RED PIN plug and wire for the light output!!!!! **** This unit is plug & play , but however to get your lights you need to run a wire from plug #8 to the pink wires in your dash from one of the switchs. **** $ 40.00 shipped in the lower 48 states!!!! Link to comment Share on other sites More sharing options...
