Sharkey Posted September 9, 2009 Report Share Posted September 9, 2009 Don't know if this is a repost or not, but saw this on e-bay and wondered what people thought? Kit Includes: T3/T4 Turbo Charger Piping Kit Oil Feed Line Kit Boost Controller 28''X8''X2.5 Intercooler Pull Type Blow Off Valve OIL CATCH TANK T3/T4 Turbo Charger: 100% Brand New, high quality, never been used or installed! This turbo is capable of 350+ HP Turbine Wheel - 2.58'' inducer,2.2'' reducer, 63 A/R Compressor Wheel - 2''inducer, 3''reducer,50 A/R, 57 trim Inlet:3'' Outlet:2'' Intercooler: Size : 28" x8" x 2.5" With 2.5' Inch Inlet/Outlet. Low Pressure Drop - Large Cooling Area - Easy Install - Tube And Fin Style Intercooler. PIPING KIT: Made of 6061 Aluminum. 2.5 inch Diameter Piping Kit With High Quality Silicone Couplers And T-Bolt Clamps. The Couplers Will Not Split Easily + The Clamps Will Not Strip Like The Cheap Kind. Strong & Tighter Fitting Use Hair Spray Between The Pipe And Coupler. Mandrel Bend 2.5 Pipe(As Shown As Picture) For High Flow And High Horse Power And Better Turbo Response Power.Some Cutting And Modification Required! Pull Type Blow Off Value : CNC Billet Aluminum, Dual Stage Handle, High Boost Power,Easy Mount Piping Set Included For Bolt-On.Including Bov Blow Off Value Flange. Fast Response One For Low And High Boost Pressure. Boost Controller: Allows Adjustable Boost PSI Settings, Light Weight Design To Be Mount Under The Hood. Hardware Is Included. Manually Control turbo boost up to 30 PSI. It's listed for Volvo 850, etc ... Link to comment Share on other sites More sharing options...
TryingBe Posted September 9, 2009 Report Share Posted September 9, 2009 It's a "universal" kit that they have listed for every make and model, made from low quality parts. Link to comment Share on other sites More sharing options...
turbor850 Posted September 9, 2009 Report Share Posted September 9, 2009 Don't buy it. Link to comment Share on other sites More sharing options...
BoostedBrick Posted September 10, 2009 Report Share Posted September 10, 2009 I was unable to talk a guy out of buying one, and for some reason he was surprised when the kit didn't fit, and the turbo was done in 10K miles. It's definitely worth saving for a real turbo. Link to comment Share on other sites More sharing options...
FCP Euro Posted September 10, 2009 Report Share Posted September 10, 2009 It's a "universal" kit that they have listed for every make and model, made from low quality parts. +1, these kits are always crap. I would only buy piping and the intercooler on ebay. I know some people have good luck with the turbos but unless it is a direct bolt on, it is not worth the work. Link to comment Share on other sites More sharing options...
esundell90 Posted September 10, 2009 Report Share Posted September 10, 2009 dont. I've seen these kits fail (on Honda's anyway) time and time again. Your better to piece your kit together yourself. Link to comment Share on other sites More sharing options...
jnderr Posted September 10, 2009 Report Share Posted September 10, 2009 If you are looking for a front mount intercooler kit a number of members have gotten the CX racing kits off of ebay. Link to comment Share on other sites More sharing options...
Auburn T5 Posted September 10, 2009 Report Share Posted September 10, 2009 If you are looking for a front mount intercooler kit a number of members have gotten the CX racing kits off of ebay. speaking of cheap quality.... at least when it comes to their intercoolers. Link to comment Share on other sites More sharing options...
