pornkingofpasayroad Posted November 18, 2004 Report Share Posted November 18, 2004 hi im new to the board and i wanted to install my own sound system so i could save a lot money. i have a volvo 850 sedan. basically just transferring stuff from my old car into this volvostuff i got: HEADUNIT stockSUBS 2 pcs. boston 12.4LF SVC 4ohmsAMP orion hcca 2100CROSSOVER kickeri have a couple of questions:1.) how much wiring to i need and what kind of wires do i need?2.) is there anywhere i can see a step by step guide on how to install in an 850? also a diagram on how to wire the batt to the amp to the crossover to the subs, etc. input would be greatly appreciated.would like to work on it asap. thanks Link to comment Share on other sites More sharing options...
spottieottie Posted November 18, 2004 Report Share Posted November 18, 2004 hi im new to the board and i wanted to install my own sound system so i could save a lot money. i have a volvo 850 sedan. basically just transferring stuff from my old car into this volvostuff i got: HEADUNIT stockSUBS 2 pcs. boston 12.4LF SVC 4ohmsAMP orion hcca 2100CROSSOVER kickeri have a couple of questions:1.) how much wiring to i need and what kind of wires do i need?2.) is there anywhere i can see a step by step guide on how to install in an 850? also a diagram on how to wire the batt to the amp to the crossover to the subs, etc. input would be greatly appreciated.would like to work on it asap. thanks←I thought it went>>>> battery>Xover>amp>subs> not including the deckbut i dunno ?? Link to comment Share on other sites More sharing options...
maiku Posted November 18, 2004 Report Share Posted November 18, 2004 there are "pinned" topics at the top of the audio board that may interest you Link to comment Share on other sites More sharing options...
steve s Posted November 18, 2004 Report Share Posted November 18, 2004 the wiring depends on where u want to put the amp, the sub, and the crossover. if u have a better idea of the layout, then u could get started with the lengths of the power wire, ground wire, rca wire that u need. Link to comment Share on other sites More sharing options...
pornkingofpasayroad Posted November 18, 2004 Author Report Share Posted November 18, 2004 im gonna put everything in the trunk. amp, sub enclosure, crossovergonna put about a 4 cubic feet box. 2 cubes for each sub. would i still be able to have access to the spare tire with a box that big? anyone have some pic of some installs in 850 trunks? thanks Link to comment Share on other sites More sharing options...
pornkingofpasayroad Posted November 18, 2004 Author Report Share Posted November 18, 2004 another question:what is a better way to get an rca signal? from the headunit itself or getting a signal from the rear speakers?thanks Link to comment Share on other sites More sharing options...
Kibim Posted November 18, 2004 Report Share Posted November 18, 2004 Getting an RCA feed out of a volvo head unit is something i've never been able to do. Either i'm missing the point, or i have obscure headunits that don't have RCA out.The stock head-units do however have an Amp out socket, on mine it looks like a Ps/2 plug. if anyone has pin-outs for these, it would be usefull . I would imagine that you'd land up building your own cable to do this though, to get low-level inputs to your amp. This is by far preferable to the next option. You can buy a little conversion unit that you wire in paralell to the back shelf speakers that provided you with a 1vp-p RCA signal for your amp. The problem with such a device, or wiring procedure, is that your subs will only ever perform as well as the output stage amplification of your stock headunit. Frequency respnose etc will be limited. The 'make your own cable' route will give you the pre-amp processing, which will be far superior.4 cubic feet is quite big, you may struggle to get into the spare tyre well. But box design will play the biggest role. Link to comment Share on other sites More sharing options...
BenW Posted November 18, 2004 Report Share Posted November 18, 2004 In regards to the pin out. A while back some guy was selling that plug here on VS that would get you the 4 pre-outs (FL, FR,RL, RR). Then you could use that to run the amp.KIBIM, dont worry, you're not missing much , IMO the factoy signal is rubbish anyhow. Link to comment Share on other sites More sharing options...
steve s Posted November 18, 2004 Report Share Posted November 18, 2004 it is pinned already up top, u should really look into these pinned topics http://volvospeed.com/vs_forum/index.php?showtopic=549http://project850.no-ip.org/installguides/.../subinstall.htmhttp://project850.no-ip.org/installguides/...=ST&f=13&t=4665 Link to comment Share on other sites More sharing options...
Chris_R Posted November 18, 2004 Report Share Posted November 18, 2004 Wow, that Orion HCCA amp and Boston 12s are going to REALLY overshadow the stock deck and speakers power-wise. You'd be best to get an 'amp kit'. they sell them on Ebay regularly and reasonably. I think even Wal-Mart carries them now. I'd say 20' feet of 4 gauge (I'm sure you'll be adding more amps in the future, if not that HCCA can use the 4 gauge) power wire. 4 feet of 4 gauge power wire and 15 feet of 'remote' wire. Honestly, I'd hate to see you blow up that fine equipment (or that fine car). I'd seek the advice of your local shop.-Chris Link to comment Share on other sites More sharing options...
theunderlord Posted November 18, 2004 Report Share Posted November 18, 2004 stuff i got: HEADUNIT stock←This is going to be your first problem. Why have all that nice gear, and use the stock deck? I've never understood. It's like putting rims on a Geo. There are so many NICE HU's that you can get for around 200 bones. And you know... christmas is right around the corner... Link to comment Share on other sites More sharing options...
Chris_R Posted November 18, 2004 Report Share Posted November 18, 2004 It's like putting rims on a Geo.Hey, hey... Watch it now. Some people would say the same about putting rims on a Volvo. BTW, Geo's (well, the Storm (manu by Isuzu)) are a HELLUVA lot easier to make fast than Volvos. Do a search for Steve Lockett and Geo Storm. He got his into the 10s. (10.427 @ 137.43 and I don't think that was his best run!)Sorry, after spending over 10 years defending my Storm it's kind of a hard habit to break. -Chris Link to comment Share on other sites More sharing options...
theunderlord Posted November 18, 2004 Report Share Posted November 18, 2004 Hey, hey... Watch it now. Some people would say the same about putting rims on a Volvo. BTW, Geo's (well, the Storm (manu by Isuzu)) are a HELLUVA lot easier to make fast than Volvos. Do a search for Steve Lockett and Geo Storm. He got his into the 10s. (10.427 @ 137.43 and I don't think that was his best run!)Sorry, after spending over 10 years defending my Storm it's kind of a hard habit to break. -Chris←sorry chris.. I should have said "like a yugo" :D Link to comment Share on other sites More sharing options...
BenW Posted November 18, 2004 Report Share Posted November 18, 2004 Hey guys, it dont matter what kind of car it is, there are nuts for every make. Link to comment Share on other sites More sharing options...
AnthonyR Posted November 18, 2004 Report Share Posted November 18, 2004 In regards to the pin out. A while back some guy was selling that plug here on VS that would get you the 4 pre-outs (FL, FR,RL, RR). Then you could use that to run the amp.KIBIM, dont worry, you're not missing much , IMO the factoy signal is rubbish anyhow.←Yup that was me. on my site is the instructions on how to make your own, although I can make another if you like.http://project850.no-ip.orgunder install guides, then RCA pre outs. Link to comment Share on other sites More sharing options...
