Modus Posted September 13, 2009 Report Share Posted September 13, 2009 I'm used to 304 and 316L SS it's very hard to tarnish those types of steel. I guess the SS braided break lines are just that. Just the braid is SS not the fittings. Why are they rusting? There IPD specials after 5 years. In the same pic is my EST Cat back exhaust after 3 years. That has some pretty good Rust pitting on it too. SS my arse Reminds me I should get my joints welded. Those clamps only work temporarily. (I have hissing) Link to comment Share on other sites More sharing options...
Mesoam Posted September 13, 2009 Report Share Posted September 13, 2009 looks ok just a little surface rust, if you gave those a quick scrub with a wire brush they would look fine Link to comment Share on other sites More sharing options...
HeavyIron Posted September 13, 2009 Report Share Posted September 13, 2009 looks ok just a little surface rust, if you gave those a quick scrub with a wire brush they would look fine Agreed, even SS will get surface corrosion due to a harsh winter environment. But, that is where the difference between SS and Aluminized is. Alumunized will have the corrosion penetrating in 3-5 years where as the SS will still be surface corrosion after that same amount of time. Link to comment Share on other sites More sharing options...
