VoOk Posted September 15, 2009 Report Share Posted September 15, 2009 i just installed a boost gauge and its jumping to 20 psi ?? any one have that problem before or anyone know how to solve it ??? Link to comment Share on other sites More sharing options...
TryingBe Posted September 15, 2009 Report Share Posted September 15, 2009 So, when you are in boost, it goes to 20psi? If so, you have a serious vacuum leak to your wastegate actuator. Fix it before the engine gets damage. Link to comment Share on other sites More sharing options...
DHV70 Posted September 15, 2009 Report Share Posted September 15, 2009 i just installed a boost gauge and its jumping to 20 psi ?? any one have that problem before or anyone know how to solve it ??? you go ALL the way to 20, or is it spiking? either way, you've got a leak, but it makes a difference in describing. If you need an actuator, pm me. Link to comment Share on other sites More sharing options...
FCP Euro Posted September 15, 2009 Report Share Posted September 15, 2009 You can check if the wastegate is good still by disconnecting the hose form the TCV and blowing into it. If the wastegate moves, it is still good. If not, replace it. Link to comment Share on other sites More sharing options...
VoOk Posted September 15, 2009 Author Report Share Posted September 15, 2009 when im at 2,500 rmp the psi is at 5 the goes to 10 around 3,000 and then if i gun it flies up to 20 when i first installed the gauge and went for a spin i was like something has to be wrong there's no way it should be at 20 psi when its nearly stock just have a intake and and catback exhaust ... Link to comment Share on other sites More sharing options...
michael-s70 Posted September 15, 2009 Report Share Posted September 15, 2009 ya way to much for 2.3 being nearly stock gotta almost be unplugged for that amoutn of boost Link to comment Share on other sites More sharing options...
850 LongBeach Posted September 15, 2009 Report Share Posted September 15, 2009 Wow 20psi ??? Check the gauge... Link to comment Share on other sites More sharing options...
db130 Posted September 15, 2009 Report Share Posted September 15, 2009 my guess would be vac line(s) punctured/not connected. Link to comment Share on other sites More sharing options...
gdizzle Posted September 15, 2009 Report Share Posted September 15, 2009 Where did you tap the vac system at? Link to comment Share on other sites More sharing options...
VoOk Posted September 16, 2009 Author Report Share Posted September 16, 2009 i taped the vac line how they show on the ipd video to install the r gauge ..one more thing my oil started squirting .. like it hits the hoood and its not right on top of the oil cap its by the oil dip stick Link to comment Share on other sites More sharing options...
socal850tuner Posted September 16, 2009 Report Share Posted September 16, 2009 i taped the vac line how they show on the ipd video to install the r gauge .. one more thing my oil started squirting .. like it hits the hoood and its not right on top of the oil cap its by the oil dip stick Check the PCV hoses... and your dipstick if its coming out of there. "Think with you dipstick Jimmy!!!" Link to comment Share on other sites More sharing options...
laird Posted September 16, 2009 Report Share Posted September 16, 2009 What modifications are done to the car? Are you using a stock ECU or do you have an upgrade. 20 PSI spikes on a chipped car would not be uncommon. If you aren't getting a code, you may have a cracked, torn or just plain old vacuum line to the wastegate. You may also have a bad line from the compressor housing to the TCV or even a bad TCV. New lines all around for sure first. Link to comment Share on other sites More sharing options...
VoOk Posted September 18, 2009 Author Report Share Posted September 18, 2009 when i turn off my car the boost level stays at 10 psi so can it be that the gauge is broken ??? Link to comment Share on other sites More sharing options...
MyCarIsRed Posted September 18, 2009 Report Share Posted September 18, 2009 when i turn off my car the boost level stays at 10 psi so can it be that the gauge is broken ??? yeah that might be an accurate assessment, what does it read for vac at idle? Link to comment Share on other sites More sharing options...
VoOk Posted September 18, 2009 Author Report Share Posted September 18, 2009 i only have 1 gauge and its the boost ..?? but when the car is ilde its at 0.. then spikes with i hit the gas Link to comment Share on other sites More sharing options...
